• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Active Member
    gregmacp
    File Save As suddenly freezes AutoSketch 9
    248 Views, 2 Replies
    04-02-2011 06:44 PM
    I have been running AS9 since it came out, after running prevous versions all the way back to Drafix. I switched to Windows & on a new machine about 6 months ago and about a week ago I began running into a bug that freezes AS9 when I try File SaveAs. The program will not respond. I have uninstalled AS9 and re-installed from the disk. Any thoughts would be appreciated; I can't work without being able to convert a dwg to an skf and back. Thanks.
    Please use plain text.
    Active Member
    gregmacp
    Re: File Save As suddenly freezes AutoSketch 9
    04-03-2011 10:05 AM in reply to: gregmacp
    Thanks to other posts I seem to have solved this problem. Steps:
    Uninstalled AS 9
    Ran CCleaner multiple times
    Used regedit to eliminate any AS related items
    Restarted the computer
    Re-installed AS 9
    Hope it continues to work.
    Active Member
    gregmacp
    04-18-2011 02:03 PM in reply to: gregmacp
    I posted that I had solved this problem (FILE-SAVE AS causes AutoSketch 9 to freeze and require a force quit) but it has come back. I'd love a working solution if anyone has one. I wonder if it is an issue with Windows 7, though I had been running AS9 on this machine for about 5 months before the problem came up.
