Hello to all,
One step beyond Harvey's suggestion is to partition the hard drive, and
create a storage drive. It has no operating system, so if the c drive
crashes, nothing is lost. We store or files, symbol libraries,
customized palettes, and templates in this drive. We have had a windows
failure, and after reinstalling windows and AS, we were back in business.
The only event this won't help is a complete hard drive failure. It's
still best to back up and store your data elsewhere, and we do, but this
setup helps as well.
Bri
Harvey wrote:
> John,
> You should set up a folder under the root, C:\, called "Drawings" or
> similar, and folders under that for each job if you wish. This sort of
> housekeeping and organization is really important. Trust me.
> This root should be your default for all your work. When you uninstall
> and reinstall AS, this folder will remain and you shouldn't have a
> problem. AS can be set to go to that folder(s) for all drawings.
> Any completed drawings should be moved to floppy or cd anyway. It's your
> history. Get it away from Windows at all costs.
> John Baum wrote:
>>Thanks, Al.
>>In AS 6.0 (under Toolbars> "Change to Interface" ) you can find the options
>>"AutoSketch Classic" and "MS Office 97 Compatible." I tried each of these and
>>they took me further away from the accustomed setup than what I have now.
>>Perhaps Harvey is right. Perhaps something has been corrupted.
>>John
>>Al Lindsay wrote:
>>>John Baum wrote:
>>>>Thanks, Paul.
>>>>I found that in the Help and the Manual. It is checked. The feature
>>>>still does not work! Has anyone any further insights?
>>>I'm not sure if you have the feature in version 6, but try right clicking on
>>>a margin, select 'Toolbars', then 'Reset Interface' This should set all the
>>>toolbars back to the default setting.
>>>Al
