AutoSketch
Dimension Formatting
1 REPLY 1
Paul 08
269 Views, 1 Reply
When importing an AutoCad 2004 DWG file into Autosketch 9 none of the dimensions are visible. The dimensions are on the drawing but extremely small ie) 1/1024 inch.
I am able to modify individual dimension formatting so that the text and directional arrows are visible.
Is there any way to modify the all the dimensions at once? There are up to 100 dimensions on each page.
1 REPLY 1
fredt
in reply to: Paul 08
Here's an idea to try on a COPY of your drawing if you don't get a better answer from someone else.
I'm assuming that you have a scaled down drawing. If not, please ignore.
Note the scale and then change the scale to 1:1. Now I assume that your text is the right size but the drawing is a zillion times bigger than the paper. Then change the scale back, but in the scale dialog box check off "apply scale change" and select the right of the two icons next to that check box.
