AutoSketch
New Member
timparsons
Message 1 of 5 (1,009 Views)
Deleting Leader Line
1009 Views, 4 Replies
09-13-2005 09:53 AM
Hi all, and thanks for your help in advance.
When i am trying to delete a leader, I can only get rid of the text, and the lines that comprise the leader. There is no way to select and delete the arrow at the end of the leader. I realize that Autosketch (version 9, by the way) does not actually have a leader per se, but makes a leader out of various other symbols. So, how to delete the arrow symbol? Any and all ideas appreciated.
Tim
*Paul Jackson
Message 2 of 5 (1,009 Views)
Re: Deleting Leader Line
09-13-2005 04:49 PM in reply to: timparsons
Hello
Drag over it with the mouse from Left to Right.
Paul
wrote in message news:4954810@discussion.autodesk.com...
ideas appreciated.
Tim
*Harvey
Message 3 of 5 (1,009 Views)
09-13-2005 06:51 PM in reply to: timparsons
Tim,
Try exploding the dimension (Firecracker on the Edit bar, among other places).
Then you can drag-select as Paul suggested. Left-to-Right will select each
component of the dimension.
Harvey
> Tim
New Member
Lloyd_Rob
Message 4 of 5 (924 Views)
04-02-2012 10:19 AM in reply to: timparsons
Tim I had the same problem deleting "Leader Line Arrow Heads" AS10.
  • You must place your cursor precisely on the point of the arrow, before the arrow willl hilite.
  • After the hilite occurs just hit the delete key.
P.S.
You might have to delete the object that the leader line is pointing prior to deleting the arrow.
Hope this helps
Member
xaxo7008
Message 5 of 5 (506 Views)
05-17-2013 11:25 AM in reply to: timparsons
After you select the entity got to Edit and click on Cut, then go to View and click on Redraw, this should work.
You are not logged in.
Ask the Community
