• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Active Member
    Mwpearson
    Convert SKD files to DWG
    1790 Views, 8 Replies
    05-23-2012 04:51 AM
    I would like to know if I purchase AutoSketch 10, can I open an SKD file and save it as a DWG so it can be edited with AutoCAD?
    Please use plain text.
    Distinguished Contributor
    Re: Convert SKD files to DWG
    05-23-2012 07:16 AM in reply to: Mwpearson
    I've sent you my contact details in PM
    Active Member
    Mwpearson
    05-23-2012 07:19 AM in reply to: StevenMac
    Hi Can you help me with my question. Thanks. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
    Member
    05-23-2012 12:58 PM in reply to: Mwpearson
    I'm sorry - was there an answer here?
    05-24-2012 12:32 AM in reply to: MrWeb
    Mike you need to find my email address in the private message area.
    Look for the envelope icon, up the top-right of the forum
    MrWeb I'll send you one too.
    Member
    sciesielski
    07-05-2012 01:41 AM in reply to: Mwpearson
    Hi!
    Same problem here - one of our clients cooperates with Autosketch users, and he receives files in .SKD format. Same question: If he buys Autosketch 10 - will he be able to open .SKD files and save them as .DWG so he can work on them in his AutoCAD?
    Trial of Autosketch is not available, right? Nothing have changed here?
    Thanks in advance.
    Staszek Ciesielski
    Member
    07-05-2012 12:29 PM in reply to: Mwpearson
    Well according to StevenMac the answer to this is YES. This does seem to be one of the world’s best kept secrets for some reason.
    IF you still have your old version of Autosketch  which produced the .SKD files on an XP PC, you can go to File-Export DXF-save.  The DXF format should open in other programs.
    Active Member
    Mwpearson
    07-18-2012 03:59 AM in reply to: sciesielski
    Hello Stasze Yes you can save a skd file as a .dwg in AutoSketch 10 and no there is no trial version. I just got back from holidays, sorry for the late response. Hope this helps. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
    Active Member
    Mwpearson
    07-18-2012 04:08 AM in reply to: MrWeb
    The version of AutoSketch we have does not support export to DXF. That was the first thing I thought of, I do not what versions does support the export to dxf. I know AutoSketch 10 can save as .dwg. Mike Pearson Eaton, Electrical Sector 5050 Mainway P. O. Box 5040, Station A Burlington, Ontario, L7L 5Z1 Tel: 905 631-4165
