AutoSketch
Carriage return inside dimension text string
5 REPLIES 5
grpeck
14808 Views, 5 Replies
Any one know how to insert a carriage return into a dimension text string?
5 REPLIES 5
in reply to: grpeck
Hello
The only way is to copy and paste into the string
JeffPaulsen
in reply to: grpeck
Use \P
It is case sensitive.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
jkadlec
in reply to: grpeck
For ACAD Mech 2013 it's \X.
\P is for older versions.
cschnarr
in reply to: jkadlec
Actually \P works in AutoCAD MEP 2018 just fine. Just posting for others whose searches might bring them here.
Kevin.Hutch
in reply to: grpeck
You have me confused CR in a text string works fine in Autosketch, I use it all the time are you sure you are looking for an Autosketch answer.
Kevin Hutch
Be part of the solution not part of the problem
(61) 4 0887 1538
