AutoSketch
Backward compatible
7 REPLIES 7
Message 1 of 8
mckinni
953 Views, 7 Replies
Backward compatible
I have Autosketch R1.02 and recently was forced to load it on Windows XP.  If I buy Autosketch 9 will it be able to use my old drawings?
7 REPLIES 7
Message 2 of 8
StevenMac
in reply to: mckinni
Post one up so I can try in v10
Message 3 of 8
mckinni
Here is a drawing from my R1.02  the file extension is  .SKD  I'll change it to ".doc" in order for it to be accepted by this forum.
Message 4 of 8
StevenMac
v10 doesn't enjoy that - http://i52.tinypic.com/2h5jqbl.jpg
Don't know about v9, 8, etc. but you probably will have to run v2.0 (or 2.1?) as an intermediary.
Message 5 of 8
mckinni
OK......thank you ever so much, for the time and trouble, to help me in this problem.
Message 6 of 8
mckinni
in reply to: StevenMac
HI Steve,
I have come across a program stating that it will convert Old SKD (v1.02) to V2.1).
I'd like to send both versions to you and doulbe check that your V10 doesn't like v1.02 but will accept v2.1
Again I've changed the extension from skd to doc for sending purposes.
And again thanks for giving me your time.
Ivan McKinnon
The attachment with 2PUPS is the v1.02
The attachment with C2PUPS is the V2.1
Message 7 of 8
StevenMac
2pups won't open, and c2pups looks like this (all text on top layer):
http://i56.tinypic.com/261lzyt.jpg
Message 8 of 8
mckinni
That's great.  This means if I convert all my v1.02 skd's to the v2.1  I will be able to use Autosketch 9 or 10 to work on the drawings and also print them.
Thanks again for your help.
Ivan
