• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Active Member
    Autosketsch R10. Can not convert (save) skf-files to dwg
    809 Views, 6 Replies
    11-16-2012 12:20 AM
    AutoSketsch R10 / Windows 7, 64 bit
    If i have saved a drawing file into skf-format it is inpossible to save a copy in dwg-format.
    Please use plain text.
    Member
    Re: Autosketsch R10. Can not convert (save) skf-files to dwg
    11-16-2012 11:13 AM in reply to: salren
    If in my AS (v9), Save-As options include: (Quote)
    AutoCAD 2000 DXF (.*DXF)
    AutoCAD 2000 Drawing (.*DWG)
    AutoCAD 2004 DXF (.*DXF)
    AutoCAD 2004 Drawing (.*DWG)
    AutoCAD R12/LT2 DXF (.*DXF)
    AutoSketch (*.SKF)
    AutoSketch v7/v8 (*.SKF)
    Autodesk Design Web Format (*.DWF)
    Bitmap (*.BMP;DIB)
    GIF (*.GIF)
    JPEG (*.JPG;*.JPEG)
    PNG (*.PNG)
    QuickCAD (*.CAD)
    TIFF (*.TIF;*.TIFF)
    Windows Metafile (*.WMF)
    (Un-Quote)
    V10 must ‘at least’ have the above, .. I would have thought. (?).
    www.veracis.org
    Distinguished Contributor
    11-17-2012 05:45 PM in reply to: PM121UK
    I don't have 10 handy at the moment, but from memory it does the same as the above formats (might also have AutoCAD 07 but I'm not certain).
    However I find DWG unreliable (some things don't save, some programs complain about opening them) and use DXF.
    Active Member
    11-18-2012 04:18 AM in reply to: PM121UK
    Yes and even 2007.dwg. The problem is that if i have made my drawing i skf-format and then try to save it in any dwg-format i get a errormessage "can not save file". I belive it is a 64-bit problem. I have tested the program in a 32-bit win 7computer and it seems to work fine. I belive the program is not redy jet. / salren
    11-30-2012 02:18 AM in reply to: salren
    I've installed Sketch 10 onto this newly formatted W7 64bit machine and it saves to DWG (2007) fine.
    Active Member
    11-30-2012 02:59 AM in reply to: StevenMac
    Hi ! Yes, but try to save in skf-format at first (from start drawing) and then save in dwg.format. Thats my problem. I have lots of drawings that i created and saved in skf-format (earlier and new ones. Know when i need to save them in dwg to share them with other colleges it dosent work. So i had to copy the files to an older computer (xp 32-bit) and open them in Autosketsch V07. There i can save them in dwg-2000 and then copying back to the new computer and open them in R10-version and there save them in dwg-2007. /HE -- *Saltsj? Reningsteknik AB* Box 2061, 132 02 Saltsj?-Boo Vinterv?gen 4c nb, 132 41 Saltsj?-Boo Tel: 08 7471112 Fax: 7470790 Mobil: 0709 520063
    11-30-2012 03:35 PM in reply to: salren
    Attach one of your files to an email and I'll take a look:
    stevenmacerakjnr[at]hotmail[dot]com
