• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    *Alm, H.
    Re:
    11-28-2001 04:02 PM in reply to: *Alm, H.
    Putting the filename in a text:
    Insert the following in the text: <%getdata(doctitle)>
    or if you want to include the path
    Insert the following in the text: <%getdata(docfile)>
    make sure the text is a formula (checkbox)
    H.Alm
    "Harvey" wrote in message
    news:3C059AF8.3CD56266@westnet.com...
    > Here's more, from various usres, for what it's worth:
    > 1) Polylines that can be dots/dashes/whatever and be of any width
    > without
    > becoming solid.
    > 2) Extended text "functions". i.e. the ability to have the filename
    > autoinserted into templates etc.
    > 3) Better print thickness control on print outs
    > 4) Dashed poly lines when the poly line thickness is greater than 0.
    > 5) version Rev14 DWG files as good as AS 6.01
    > 6) AutoCAD 2000 files open and save
    > 7) Microstation files open and save.
    > 8) Drafix CAD files open and save.
    > 9) Trim a bunch of lines to another line with a window select.
    > 10) One of the major bugs is with the installation of either/both QC &
    > AS into a
    > Windows NT environment. This also includes Windows 2000 Professional.
    > After installation, one must swim through crock infested waters to make
    > manual Registry changes to set certain defaults that are automatically
    > set
    > in Windows 95/98. This is not good.
    > 11) AutoDesk have a problem with the metric system....and a major
    > problem is
    > that to transfer multi-lined text in ANYTHING other than (I think....the
    > bug
    > has been reported previously) the default justification, one must
    > convert
    > the QC/AS drawing to some level of imperial measurement before the text
    > can
    > be opened successfully in LT2000, which then of course, screws around
    > with the scaling. If it wasn't for that, LT opens QC/AS files VERY well.
    > END
    > Hakon Alm had a series also. I don't remember if they're covered above.
    > The long post I wrote in this forum can't be accessed anymore because of
    > a glitch that occurred in the server last year - a lot of posts were
    > lost and I think that big one got scuttled. Maybe someone at ADSK has
    > it, god forbid.
    > But that's most of them, courtesy of Stephen Tall, Len and Ric. And you
    > and I. There were many others who echoed similar requests, but I can't
    > credit them unfortunately.
    > Paul Jackson wrote:
    > > Thanks harvey
    > > Most were in a list I am putting together and I will put in the text and
    > > printing stuff in right now.
    > > Now back to updating the Manual to V8, Uch.
    > > PJ
    > > news:3C058B55.AA03753C@westnet.com...
    > > > > How does one go back that far, is there a way to do it.
    > > > > I would like to get a copy of the list and I can then see what has
    been
    > > > > implemented !
    > > > If you had Netscape you could do a quick offline search in the
    newsgroup
    > > > and find it. But you really have to know what you're doing, so I don't
    > > > advise it for you.
    > > > Anyway, here's what I wrote back then, November 11, 2000:
    > > > OK I'd like to set out some thoughts on what would be nice to see in
    > > > future revisions of AutoSketch. This doesn't include any corrections
    to
    > > > the current R7, rather these would be new features and, if
    encorporated,
    > > > would certainly bust the market for lower end CAD packages. Nothing
    like
    > > > blowing the competition out of the water, aftre all.
    > > > Clearly all these can't be added to AS, and some are more important
    than
    > > > others. I'd leave those decisions to the marketing folks who should
    have
    > > > their finger on the pulse somehow.
    > > > However, these thoughts are based on what I've seen currently in the
    > > > market with other packages, and *may* not add significantly to the
    cost
    > > > of the next revision. But it's certain if encorporated, they would add
    > > > to the cost.
    > > > If anyone has other ideas or suggestions, please add them to the
    thread.
    > > > Maybe we can schnoogle AD to read this and take it seriously.
    > > > 1. Batch import for all common file types. (dwf, wmf, dxf, IGES,
    etc.),
    > > > comaptible with 2.1.
    > > > 2. Back-compatibility of R7 with R6.
    > > > 3. VB and/or C++ programming interface, basic script macro language.
    > > > Better even a direct text macro like what's in Word or Excel.
    > > > 4. Tracing bitmaps automatically, similar to wintopo
    > > > 5. Batch printing.
    > > > 6. Text to follow an arc or curve. (boy, would I love *that*)
    > > > 7. Batch printing, from the program itself.
    > > > 8. Generate a material list automatically.
    > > > Please add some to the ones you most prefer to see, or add others if
    you
    > > > don't see them. Response is encouraged.ENDQUOTE
    > > > So there ya go. There were others, and I think you added your own
    > > > thoughts in the thread also. I'll show you those if you'd like. You
    even
    > > > complimented me, you foolish boy! The first and last time that's
    > > > happened. A red-letter day.
    > > > I think there was a followup where I detailed all the thoughts from
    > > > other people, and even gave credit, although I was loathe to do that.
    Please use plain text.
    *Rafuse, L.
    Autosketch 8.0 - Wishlist for Paul Jackson
    11-28-2001 08:56 PM in reply to: *Alm, H.
    B Pike wrote:
    >Snap to End we have, Snap to Other End, using a toggle key, I believe would
    >be extremely useful.
    That would be nice.
    Len Rafuse
    Vision Engineering
    *Rafuse, L.
    Snap to the other end
    11-28-2001 09:04 PM in reply to: *Alm, H.
    Never found a use for Jump snap before.  I would zoom out to seee the other end of a line to snap to it.
    I just need to memorize it: Type J for Jump snap to other end...Type J for Jump snap to other end...
    Holding the control key to snap to the other end would be nicer.
    Len Rafuse
    Vision Engineering
    H. Alm wrote:
    Snap to the other end: Use Jump snap and set percentage = 100%
    "B Pike" <bpike@DELETETHISPARTmagna.com.au> wrote in message
    news:816517C9AD3C0D0B80A7145BFAB0ACC5@in.WebX.maYIadrTaRb...
    Here's a feature I've been wanting for years -
    would
    *Harvey
    Re:
    11-28-2001 09:28 PM in reply to: *Alm, H.
    Somehow I get the feeling that those of us who purchased AS7 were beta
    testers.
    I suppose it *is* one way to get the job done, and it speaks to the
    pressures ADSK has to get a product out.
    However, judging from the types of problems, the lack of patches, and
    the heat it's generated with users, it may not be the most effective way
    to release subsequent versions.
    User Discretion may be the watchwords in the future.
    I was a strong proponent of AS6. Sure, there were missing features like
    macros, line weights, etc. But the questions in the newsgroup were about
    how to use the program, not complaints. It was entertaining to read all
    the different ways to accomplish the same ends and attempt to find new
    ways. The program seemed solid.
    When AS7 was released, the nature of the newsgroup changed. I think Rod
    mentioned that there was a noticable drop in the number of posts. I
    noticed also. Either people were losing interest or they shied away from
    purchase after reading the issues about it.
    It would be useful to have Paul or similar (goodness, imagine someone
    similar!!) recount the features in AS8 in the newsgroup and detail if
    all the problems (opportunities?) raised have been solved - or addressed
    in some way.
    Anyone have any comments?
    *CL
    11-29-2001 01:27 AM in reply to: *Alm, H.
    Side note: Corel Draw has and always have used the "Home" and "End" keys for
    this purpose. there is a start and end to every line !!
    Chris L
    > That would be nice.
    > Len Rafuse
    > Vision Engineering
    *Selzer, Gerhard
    11-29-2001 06:24 AM in reply to: *Alm, H.
    Len,
    What a relieve. Thought I was a complete idiot.
    When this matter came up again few days ago,
    I went back to Paul's book and fooled around with
    it for several hours in case I missed something.
    Came to the same conclusion as I did 3 years ago
    that there better ways.
    Gerhard, R6.01
    > Len Rafuse
    > Vision Engineering
    > > "B Pike" wrote in message
    > >> believe
    > > would
    *Pike, B
    11-29-2001 06:37 AM in reply to: *Alm, H.
    Thanks H. Maybe I should read the manual - heaven forbid!!.
    Barry Pike
    "H. Alm" wrote in message
    news:BE18A0D2C372587FF7A2FABFD0E6D752@in.WebX.maYIadrTaRb...
    > would
    > > Also, the tick box for copy or move during entity transformations - can
    > this
    > > be made bigger? - at the moment it is tiny when on a 19" monitor at 1280
    > > resolution. Could Copy or Move be selected by a toggle key also.
    > > Regards
    > > Barry Pike
    > > > without
    > > > becoming solid.
    > > > AS into a
    make
    > > > set
    > > > problem is
    think....the
    > > > bug
    > > > convert
    text
    > > > can
    well.
    > > > END
    above.
    of
    > > > it, god forbid.
    you
    > > > Paul Jackson wrote:
    > > > > Thanks harvey
    > and
    > > > > PJ
    has
    > > been
    > > > > > > implemented !
    > > newsgroup
    > don't
    > > > > > advise it for you.
    in
    corrections
    > > to
    > > encorporated,
    Nothing
    > > like
    important
    > > than
    should
    > > have
    the
    > > cost
    > add
    > > > > > to the cost.
    > > thread.
    > > etc.),
    language.
    > > > > > 5. Batch printing.
    if
    > > you
    You
    > > even
    from
    > that.
    *Jackson, Paul
    Autosketch 8.0 - Thanks
    11-29-2001 09:57 AM in reply to: *Alm, H.
    Hello Harvey and Others
    Thanks for the list of ideas and these will be sent on as soon as I get my
    domain back, so apologies if anybody has been trying to e-mail me but our
    domain got trashed and it will be a few days before we get it back.
    Some of the requests I am sure have been included or fixed in V8 and the
    rest will be in the hands of the gurus at Adesk to contemplate for the
    future.
    Other snipets I will include in the next run of Hands On A House with the V
    8 add ons once I get my hands on the retail version.
    Paul Jackson
    Resolve Computing [Oz]
    *Norris, Ric
    11-29-2001 10:40 AM in reply to: *Alm, H.
    Hi Paul,
    I realise I have been given the opportunity to submit a formal "wish list"
    to you....but I couldn't think of any apart from what has been mentioned
    before.....until now.
    What I would like for Christmas is a FULL-TIME, FULL SCREEN cursor
    (cross-hair)....emphasis on the FULL-TIME...not 1 that cuts in when a
    command is selected.
    Lucky your servers are down....I may have missed the boat....but then as you
    are living on the west side, that may have been a poor choice of
    words.....!!!!!
    Ric.
    http://users.bigpond.net.au/cavedrawings
    "Paul Jackson" wrote in message
    news:smileyvery-happy:AC5620C8B04646FC32F78B8D7AD9E29@in.WebX.maYIadrTaRb...
    > future.
    V
    > Paul Jackson
    *Pike, B
    11-30-2001 06:19 AM in reply to: *Alm, H.
    A feature from Drafix that would be good was the Alt + Del keys together
    would undelete the last item(s) deleted. This only worked on deleted items,
    so is different from the Undo button, but is a lot quicker.
    Also, on the edit bar for text, could some extra attributes be added for
    editing, particularly the hiding/showing of extension lines.
    Thanks Paul
    Regards
    Barry Pike
