AutoSketch
Autosketch 10 window cut off
2 REPLIES 2
1145 Views, 2 Replies
My autosketch program is not allowing me to view everything that I need to view in pop up windows. I have attached a picture of what the issue is. The "drawing options" window is cutting off the right half of what should be presented in the window
2 REPLIES 2
david.lau
This will be hard to troubleshoot because this program is not tested under Windows 7.
http://forums.autodesk.com/t5/AutoSketch/Autosketch-10/td-p/2746635
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_programs/will-autosketch-10-run-u...
I have 2 suggestions:
1. Run it in compatiblity mode.  It is similar to step 4 here:
http://upandready.typepad.com/up_and_ready/2013/07/unsupported-autocad-2014-on-windows-vista.html
2.  Run it in  Windows XP Mode.  If the UI looks good, then use it in XP mode.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
David Lau
in reply to: david.lau
Have a look for microsoft .net updates if you have no joy.
