I also have this problem with dialogue boxes, but was told by the support folk that it is because I'm running Windows 7 which is not supported by Autosketch.
I have tried altering font sizes within Windows, scaling etc. but so far nothing has solved the problem.
Have you found a solution ?
I use W7 with all versions of AutoSketch without any issues. (UAC Off)
Try changing your screens resolution and see what the difference is.
Paul Jackson
I have already been through all the following, without success:
Nothing I've tried so far solves the problem that you can see in the attached screenshot.
I'm open to any other ideas...
This might sound a bit strange, but set your default printer to a different driver and then restart AutoSketch.
Also fire windows up in safe mode.
Are you using 32 or 64 bit??
Paul
I'm running Windows 7 Professional 32 bit
These did not solve the problem - I still have the effect shown in the previous screenshot
The problem can be solved by reinstallning sserife.fon. Somehow this file can get corrupted. Unzip the attached file and open the font file. Click on it and then click on "install". Same problem seems to exist with other software in WIN 10 but can be fixed this way.
