• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoSketch
    Active Member
    AutoSketch 10 Windows 7 32-bit Saved Backup functionality not working
    361 Views, 0 Replies
    01-24-2013 07:03 AM
    When trying to save to a local drive utilizing the *.BAK file, the *.BAK file is not being saved correctly.  Initially, when the file is new and there is no *.BAK file, the file that AutoSketch creates is fine.  However, once the *.BAK file is created, the file will not save correctly to the *.BAK file.  You can see this not being accomplished correctly by looking at both the file size and the data within the *.BAK file.  If the user clicks on the save button twice in a row, it does look like the data does get saved to the *.BAK file.  I think AutoSketch 10 may have some glitches in saving file data.
    Please use plain text.
