With regard to the proprietary content, while I understand that you don't
want to publish any sensitive material, you could edit or delete all references
as to who it's for and what it does etc, rescale it (as in edit>transform>scale)
by some peculiar scale, and then post it.
Other than that, the only thing I could suggest is to make a copy of the
file to play about with. Open the copy and start deleting things and see if the
problem still occurs. If you suspect it's caused by text, try using the
Selection Modifier () to select all the text and delete it. With a bit of
trial and error you might be able to narrow it down to what item is causing the
problem.
Al Lindsay
In news:17844171.1096050092623.JavaMail.jive@jiveforum1.autodesk.com,
zingher typed:
> Rick, Thanks for your response. The HW is an IBM Think T40 running
> WinXP Pro, all in excellent condition. I have used this steadily &
> without trouble during over 9 months, using many applications,
> including ASv8 before a recent upgrade to ASv9. Those applucations
> used the same display drivers, same mouse drivers, same HW. This
> suggests these drivers probably are NOT the source of the problem.
> Particularly since I am an inaccurate typist, it does happen that I
> ocassionally hit unintended keys or key combinations. Is there some
> way this could cause this problem? Because of proprietary content, it
> would be difficult to post the file. Any further suggestions would
> appreciated. With appreciation, Arthur Zingher
