• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    maxim_k
    Re: large format PDF files
    08-13-2012 06:48 PM in reply to: gregory
    Hi Gregory,
    In order to improve the situation try to change "line end style" and "line join style" in your CTB file from "diamond" and "miter" to "Use object line end style" and "Use object join style" option accordingly.
    PS. Unfortunately I'm not in LA area, but rather on the other side of the world (Moscow, Russia)
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Please use plain text.
    Active Contributor
    08-14-2012 09:19 AM in reply to: maxim_k
    Dude!  You're amazing!
    Thanks so much!
    -G
    Member
    08-22-2012 11:13 AM in reply to: makitecture
    I recently switched to using AutoCAD for MAC, and I am trying to find out whether you can print to PDF with NO printer installed with a MAC computer. Basically, if I work from home, (I do not have any physical printer), but still need to send my clients drawings. I cannot figure out a workaround since previously i used the DWG to PDF option. I don't understand how any home office could use MAC version of AutoCAD with this type of limitation.
    Also i have had issues with the quality when I have had access to printer, and then choose the "save as PDF". The lines seem to have wacky vector points and text is warped and elongated. Any ideas on how to troubleshoot this?
    Active Contributor
    08-22-2012 11:25 AM in reply to: kdahl81
    If you have a printer installed already but it's not online you can still print PDF's...  Do you not have any printers installed?
    Member
    08-22-2012 11:41 AM in reply to: gregory
    No printers installed on my home computer. Never had a need in the digital world of 2012. So AutoCAD for MAC requires users to have at least one printer to be installed in order to print anything to PDF? I read another post where someone recommended to install a phantom (fake printer) but I have no idea how to do this and also resent AutoDesk, Apple, and Adobe for not figuring this out.
    Valued Contributor
    David_Stacey
    08-22-2012 03:09 PM in reply to: makitecture
    All you need to do is install an IP printer in System Preferences (same place as you'd install a physical printer). Make up a fake (but valid) ip address and away you go.
    I also recommend you install the Gutenprint drivers first. Just google for this.
    I use a HP Designjet driver but you could choose something else if you want.
    Member
    08-26-2012 07:25 PM in reply to: gregory
    No printers installed on my home computer. Never had a need in the digital world of 2012. So does AutoCAD for MAC requires users to have at least one printer to be installed in order to print anything to PDF? I read another post where someone recommended to install a phantom (fake printer) but I have no idea how to do this and also resent AutoDesk, Apple, and Adobe for not figuring this out.
    Valued Contributor
    David_Stacey
    08-26-2012 07:41 PM in reply to: kdahl81
    Installing a 'fake' printer is easy.
    1. Go to System Preferences, Click on 'Print and Scan'.
    2. Click on the '+' icon to adda new printer
    3. At the top of the Add Printer window, click on IP
    4. Protocol should be IPP, use 203.56.1.20 or some other made up IP address
    5. Queue can be left blank
    6. Select a printer from 'Print Using'
    7. Click on 'Add' button.
    If you install the Gutenprint drivers for Mac OS X, you can use a different printer driver like HP Designjet (or similar) so that you can print to large format page sizes as well (without having to add custom paper sizes).
