• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Member
    Accepted Solution
    extruding shapes imported from illustrator
    386 Views, 5 Replies
    01-11-2013 07:33 AM
    I'm currently having some trouble using Illustrator shapes imported in Autocad 2013. The shapes are created using illustrator CS6 (no line / no fill), exported for Autocad 2004/2005/2006 as a dwg file. This dwg is imported as a block in Autocad without trouble. The shapes appear in Autocad as Splines. OK.
    I designed a shape (using illustrator) that I want to extrude in Autocad, I can import it, it is nicely displayed as a spline, but the problem is I can't extrude it.
    So I tried to do the same with simpler shapes :
    - Square drawn using square tool -> Ok, can be extruded
    - Circle drawn using circle tool -> Ok, can be extruded
    - Hand drawn polygon using plume tool (closed shape) -> Ok, can be extruded
    - Hand drawn shape with some curves using plume tool (closed shape) -> CAN'T BE EXTRUDED
    - Complex shape (square and circle partially merged together using pathfinder) -> Ok, can be extruded
    - My shape (heatsink section) closed shape -> Can't be extruded
    You can see shapes here : http://img812.imageshack.us/img812/5466/capturedcran20130111162.png
    It mostly works, but it seem that I can't extrude shapes that have hand drawn curves ?
    Has anyone already experienced this ? Am I missing something (Autocad Newbie) or is it an incompatibility issue ?
    Thanks for your help,
    Julien
    Please use plain text.
    Employee
    Re: extruding shapes imported from illustrator
    01-14-2013 11:09 PM in reply to: nadph10
    Hi Julien,
    Are the objects imported shown as Spline type or block type? You can see the object type by selecting it and it is shown in Properties Inspector.
    If it is block type, you can explode it and then extrude.
    If it is shown as Spline type, can you please share a simple drawing with the object?
    Wei
    Member
    01-15-2013 01:01 PM in reply to: wei503
    Please find the files here : http://cloud.julienmaire.fr/public/shapes.zip
    Above the line, shapes created whith AI preset tools. Under the line, Hand drawn shapes using plume tool.
    I thought I couldn't  extrude the hand drawn shapes containing curves. But I have been able to extrude a hand drawn circle, but if change the way I make it, I can not extrude it anymore (see the 2 circles at the bottom, one has handles on the closing point, the other has no handles on the closing point). I don't understand...
    *Expert Elite*
    maxim_k
    01-15-2013 10:30 PM in reply to: nadph10
    Hi Julien,
    I examined your files and have found, that when I attempt to extrude shapes, that you can not extrude, I get an error from AutoCAD:
    Modeling Operation Error:
         Sweep self intersects
    Unable to extrude the selected object.
    That means, that these shapes (they are splines in fact) have self-intersections, but AutoCAD can not extrude such objects. You will ask: why they have self-intersections? - I don't exactly know, maybe Illustrator created them in such a way.
    If you really need to make 3D Solids from these shapes you can, for example, use LOFT command instead of EXTRUDE. Just copy the shape in extrusion direction to the required distance and create Loft object using original shape and it's copy. In your drawing this works only for "comb". For others I first converted them to Polylines with SPLINEDIT or PEDIT command and then extruded as usual.
    See attached DWG - red objects.
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    New Member
    01-29-2013 04:02 AM in reply to: nadph10
    Hi Julien,
    I had the same problem. Some of the splines extrude and some wont. Even after extrusion i've got problem with extruded shapes with union and subtract commands.
    As a workaround, I've used the pedit command on splines and converted them to plines. Everything worked fine after that.
    Hope this helps to solve your problem.
    Phani
    Member
    01-30-2013 07:09 AM in reply to: GroupFMG
    Thanks guys for your help !
