• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Member
    margie_lo
    Accepted Solution
    comprehensive list of commands and settings
    207 Views, 2 Replies
    01-18-2013 02:43 PM
    Does anyone have a comprehensive list of standard key in commands and all the various settings options?  For example when you key in selectionmode and can select the numbers from 0-2.  What exactly does each number translate too?  I just haven't been able to commit it all to memory.
    Thanks!
    Please use plain text.
    *Expert Elite*
    maxim_k
    Re: comprehensive list of commands and settings
    01-21-2013 01:10 AM in reply to: margie_lo
    I think, that:
    - online or offline Help system is the best way to get information about command options and System variables settings, just start a command, or enter variable name at the command prompt (hit Return) and then hit F1 key - Help will opens on corresponding page with description of all options (or variable settings);
    - PDF documentation could serve as a kind of comprehensive list that you can take with you everywhere (just put it to your tablet or smartphone :smileyhappy: ), you can download documentation from here (look for "Command Reference" at first):
    http://docs.autodesk.com/ACDMAC/2013/ENU/PDFs/PDF%20Documentation.htm - for AC 2013 for Mac
    http://docs.autodesk.com/ACDMAC/2012/ENU/PDFs/PDF%20Documentation.htm - for AC 2012 for Mac
    http://docs.autodesk.com/ACDMACLT/2013/ENU/PDFs/PDF%20Documentation.htm - for AC LT 2013 for Mac
    http://docs.autodesk.com/ACDMACLT/2012/ENU/PDFs/PDF%20Documentation.htm - for AC LT 2012 for Mac
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Member
    margie_lo
    01-25-2013 11:08 AM in reply to: maxim_k
    Thanks.  That's exactly what I needed.
