AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Tool Bars and Palette Locations!!!!
34 REPLIES 34
Message 1 of 35
drds
1798 Views, 34 Replies
Hey Guys!!!!
I am using AutoCAD 2013 for Mac and I am having an issue with Tool Bars and Palletes. Every time I open the program the Tool Bars and Palettes are in different locations. I find this to be a pain in the **** as I then have to move them around to the place I want them to be.
I am using a MacBook Pro 15" and I connect to an external monitor and I want all of my Palettes on one screen and my Tool Bars and Work Space on the other.
If there is a lisp routine I can run or if there is a way to lock this in that would be great.
I think this is something I have mentioned since the inception of the new Mac version of the software. I have been a beta tester from the beginning of the new Mac versions and I was hoping that this would have been fixed or added in by now.
Please send help!!!!!
34 REPLIES 34
Message 2 of 35
maxim_k
in reply to: drds
I never have tried to work with external monitor connected to my MacBook (I wish to test, but I do not have an external display adapter 😞 ), so I can not test the issue you have with Palettes position. Maybe the problem you encountered in earlier releases of AC for Mac are still here.
I think that all settings for Palettes position are saved in ~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support/Profile.aws file.
Just for sake of interest - could you post your Profile.aws file here? (you have to compress it in order to be able to attach to the post)
I'll compare mine and yours. Before uploading file - setup your workspace as you need on two monitors and quit AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 35
drds
in reply to: maxim_k
Here is the file you requested?.
Thank you.
Dana W. Rosenthal, AIA
DRchitecture & DSign
e. DRchitectureDSign@comcast.net
Message 4 of 35
maxim_k
in reply to: drds
Hi Dana,
No file attached (there is a problem here with attachments here on forums). Try to attach ZIP archive (compress Profile.aws) or send it to my email:
mkanaev at yandex.ru
M
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 35
drds
See if you get this one?.
Thank you.
Message 6 of 35
maxim_k
in reply to: drds
No 😞
Which browser do you use - in FF I also can not attach files, but in Safari - I can.
Or simply send to my email
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 35
drds
Lets see if the one works.....
Message 8 of 35
maxim_k
in reply to: drds
Get it now.
Which resolution you have on external monitor attached to Mac Book?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 35
drds
It is set for Best for Display which is 1680x1050
Thank you.
Message 10 of 35
maxim_k
in reply to: drds
In Profile.aws file I see, that "total" resolution of your display is 3120x1050, so it appears that AutoCAD uses height from your external monitor measurement and width as a sum of measurements of Mac Book and external monitor (1680+ 1440=3120) for virtual display. And this seems correct. But your Mac Book resolution height is in fact smaller then 1050 pixels - it should be 900 as I think.
Maybe snag is here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 35
maxim_k
in reply to: drds
Could you also, please, attach here quick sketch of your dual monitor system with palettes dimensions and positions?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 35
drds
Here is my Monitor Setup
Macbook Pro 15" (Left)
Dell E207WFP Monitor (Right) which measure 17"w x 11"h (20" diagonal). Panels are 7.5", 3.5" and 4" wide.
Thank you.
Message 13 of 35
drds
I am sure you are correct on the resolution as you will see below?.
Thank you.
Message 14 of 35
maxim_k
in reply to: drds
Unfortunately there are no screenshots (attached images) in your posts 😞
Try to attach ZIP archive (compress images and attach to the post)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 35
drds
Thank you.
Message 16 of 35
maxim_k
in reply to: drds
Hi Dana,
I'm still waiting for screenshots from your monitors at the moment when you running AutoCAD with your preferred workspace setup. Is it possible?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 35
drds
Message 18 of 35
drds
in reply to: drds
The Panel sizes are 7.5", 3.5" and 4" on the Dell Monitor....
Message 19 of 35
maxim_k
in reply to: drds
OK,
I got your screenshots and tomorrow I will try to reproduce on my Mac Pro with two monitors connected.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 35
drds
I am hoping you can find a way to get them to stay in one place. I hate moving them every time I open AutoCAD!!!!
Any idea on when Express Tools will be available for the Mac version or something close to it???
Thank you.
