• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Member
    The PMP folder was not found ...
    989 Views, 5 Replies
    08-30-2011 04:31 AM
    Just installed the 2012 trial and cannot get it to export a PDF to the desktop.
    The error in the log is:
    ERROR: Unable to create the requested media size as a custom size.
    Sheet: test-A2 - Error(s) Did Not Plot
    File: /Users/Mark/Desktop/test.dwg
    Category name:
    Page setup:
    Device name:
    Plot file path:
    Paper size:
    ERROR: The PMP folder was not found and is required for custom paper size creation.
    ERROR: Internal error attempting to create custom paper size.
    Has anyone else had this issue?
    Looks like it cannot write to the file/access the folder...
    Please use plain text.
    New Member
    abdul31
    Re: The PMP folder was not found ...
    11-13-2011 07:31 AM in reply to: mawelby
    Hey,
    I have the same problem.
    Try with these settings:
    File Format : pdf
    What to Export : Display
    Page Setup : Override
    or
    File Format : pdf
    What to Export : Extents
    Page Setup : Override (A4)
    They should work
    Good Luck
    New Member
    04-21-2012 06:58 AM in reply to: mawelby
    Hi there,
    I'm having the same problem when trying to plot some 11X17 sheets.
    Where do I change these setting?
    Thanks a lot!
    New Member
    07-10-2012 10:14 AM in reply to: mawelby
    I have had the same trouble.  I can plot single sheet PDFs but not multiple sheets.
    I got around this by Exporting to PDF.  Pick the File pulldown, pick export.  In the dialogue box give It a name, (at the top), Below choose PDF Files under File format, under what to export choose All Layouts and under Page setup choose Current.
    This should create a multiple sheet PDF file that uses the proper sheet settings.
    Make sure you specifiy the right folder so you can find the PDF you just made when you want to email it or save it to a disk.
    Good luck
    Active Member
    12-03-2012 10:32 AM in reply to: mawelby
    I had this issue after installing AUTOCAD on my MAC.
    After many hours of frustration, I figured out the issue. Paper Size in relation to printer. (even though I want printing from this machine)
    I am plotting 24" x 72" -- All you have to do is create a papers size that is the EXACT size you are loking ot plot.
    After creating the paper size for the PLOT SIZE, the errors went away. I am now able to plot with ZERO errors.
    Hope this helps.
    New Member
    01-03-2013 11:31 AM in reply to: Jake333
    Finally!
    Thank you, I've been looking for an answer for this too long. Thanks for your post!
