• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Text box crushes/can't create or change text style
    248 Views, 6 Replies
    03-04-2012 09:13 AM
    I am having problem with opening the Text STyle box.  It shows for a second on my screen and then dissappears and my computer freezes after that.  I need to create new Text Style , how can I open the Text style box?
    Please use plain text.
    *Expert Elite*
    maxim_k
    Re: Text box crushes/can't create or change text style
    03-04-2012 09:53 AM in reply to: eglupe
    Try:
    1. to "Reset Application Options" from Application tab of AutoCAD Preferences
    or
    2. Just exit AutoCAD and try to delete AutoCAD preferences file from ~/Library/Application Support/Preferences folder, it's should look like "com.autodesk.AutoCAD.R18....plist" (the remaining ... depends on AutoCAD version)
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    *Expert Elite*
    maxim_k
    03-04-2012 12:09 PM in reply to: eglupe
    And one more question: do you use (from time to time) external monitor, or dual monitor configuration on your Mac with AutoCAD?
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    New Member
    10-03-2012 04:25 PM in reply to: maxim_k
    Thank you! I was having the same problem, with a few other windows as well, page setup for example. I run am running on an iMac no external monitor. I thought it may have something to do with limited processing power (2.8GHz when ACAD wants minimum of 3).
    *Expert Elite*
    maxim_k
    10-03-2012 09:09 PM in reply to: eeneska
    Hi
    Sorry, I did not understand. Have you managed to solve the problem with "disappearing" dialog boxes?
    If you have, that's OK.
    And about processor speed - it doesn't affect dialog box behavior at all, it seems that you confused processor speed and amount of RAM (in Gb).
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    New Member
    10-08-2012 06:59 AM in reply to: maxim_k
    Yes it did solve my problem with the dialog boxes disappearing. Thank you.
    *Expert Elite*
    maxim_k
    10-08-2012 09:53 AM in reply to: eeneska
    Thanks for reply
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
