AutoCAD for Mac
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Scales issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've added 1:25 on my scale list. In annotation scale it shows 1:25 but under standard scale it doesnt show. Why would this be? For a viewport shouldnt your annotation scale be 1:1 and then for the page scale you set your standard to 1:25 or which ever?
Mark.
Re: Scales issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Mark,
Thank you for reporting this issue to Autodesk!
I have logged a defect for this and will keep on tracking with it.
Leaf
Autodesk Test Engineer
Re: Scales issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Mark,
Not sure that I understand your question correctly, but the general workflow for adding scale list is:
1. If you want to add scale to current drawing, then you should use SCALELISTEDIT command (Menu: Format
Scale List ). When you add new scale to this list it it automatically appears in annotation scale list and in viewport scale list for current drawing.
2. You can add new scale to the list of scales in AutoCAD Preferences (Menu: AutoCAD -> Preferences->"Default Scale List..." on "Units and Guides" tab), this will add new scale to AutoCAD preferences file (REGISTRY - in Windows version of AutoCAD). After you add a new scale to the default scale list in AutoCAD Preferenses, you can use the Reset button in the Edit Drawing Scales dialog box to add the new scale to your drawing.
Maxim
MARSS
http://macacad.wordpress.com
Re: Scales issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Scales issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hmm, not really a bug, because on my system everything works correct in both 2011 and 2012.
Maxim
MARSS
