• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Active Member
    Accepted Solution
    Problems with plotting on larger papersize
    197 Views, 4 Replies
    04-07-2012 02:06 PM
    I made a page setup with a custom papersize of 2000x914mm. Fine so far. The printdialog however reports a constraint: "paper size is out of printer specifications (see Page Setup dialog)" and AC refuses to plot correctly. My colleagues on Windows can plot on this size on the same  HPT790ps so the plotter is not the bottleneck. Any ideas?
    Please use plain text.
    *Expert Elite*
    maxim_k
    Re: Problems with plotting on larger papersize
    04-07-2012 09:18 PM in reply to: wimvreugdenhil
    Have you checked, that you enter correct numbers for custom paper size? In Mac OS all fields in Print/Plot setup are in cm, not in mm, so if you want 2000x914 mm paper size, you have to enter 200x91.4 cm
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Active Member
    04-08-2012 12:41 AM in reply to: maxim_k
    Hi Maxim,
    Yes i made the paper in cm.
    Now at home i try a paper of 91,4 x 200 cm (instead of 200 x 91,4 cm) and the constraint has disappeared. Unfortunately here I am not able to plot so tomorrow i will give it a try at the office.
    Wim
    *Expert Elite*
    maxim_k
    04-08-2012 07:44 AM in reply to: wimvreugdenhil
    Hi Wim,
    yes, the first field in Custom paper size dialog is width, the second - height (read: how long the paper is). Then you can change paper orientation in Page setup dialog, just below paper size drop down list.
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Active Member
    04-08-2012 11:03 AM in reply to: maxim_k
    Thanks Maxim, this is definately the way to go.
    Wim
