• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    New Member
    macabyte
    Open Drawing - Not and Educational Product Drawing???
    7048 Views, 13 Replies
    10-27-2010 07:49 PM
    Giday there I have downloaded "Autocad" for mac and have activated it as a student.
    Now when I start the program I receive an error message.
    "The drawing file being opened was not created by a productfrom an
    Autodesk Education Suite.If you save this drawing, it will always be
    plotted with the following plot stamp.
    PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT
    It is recommended the you save this drawing with a different name.
    Sorry but I'm totally new to this - where do I go to change this?
    Thanks in advance for your help.
    Please use plain text.
    Active Contributor
    Re: Open Drawing - Not and Educational Product Drawing???
    10-27-2010 10:19 PM in reply to: macabyte
    If the drawing you are opening in the educational version was created by a regular Autocad product, the educational version will add the PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT plot stamp when it's saved. if you don't want to have that permanently added to the original file, you need to change the name as you save. Then the original drawing file can be opened with other Autocad products without having the PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT plot stamp added
    I don't believe there is any way to change that.
    New Member
    macabyte
    10-27-2010 11:24 PM in reply to: macabyte
    Thanks for the reply. This is not one of my drawings as I have not done anything in the program as yet. This is the very first thing that comes up before the program starts. If I am unable to change this, annoying as it is, then I will have to persevere with it. Like is said "it only happens when I launch the program.
    *Expert Elite*
    pendean
    10-28-2010 04:37 AM in reply to: macabyte
    Your AutoCAD is opening a file that has never been saved in the EDU version: it ALWAYS opens a file when you start the program, nature of AutoCAD, so that is the problem. The above answer, while accurate, is not relevant the answer to your issue I believe.
    You'll have to wait for someone that uses EDU software regularly to answer why it happens and if there is a known cure, unless you wish to have someone help you create a startup file you can always use.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    tommyjames337
    03-23-2011 10:54 PM in reply to: macabyte
    I have this exact same problem, and it's something that REALLY needs to be fixed! In my drafting class, I can't print anything because it has the stupid message all over the prints! Just DUMB! PLEASE AUTODESK! HEEEEELLLLLLPPPP!!!!
    Member
    Secu11
    04-20-2011 02:12 AM in reply to: macabyte
    I followed the advice, changed the file name, the file path ut without any effect. I hope there is a better solution for this annoying problem.
    Member
    ecmruss88
    08-30-2011 08:37 PM in reply to: tommyjames337
    I am having the same problem... did you find a way to open it??? It just keeps trying to load and then nothing happens??
    Help
    Member
    ecmruss88
    08-30-2011 08:38 PM in reply to: macabyte
    Hi, just wondering if you found a way to fix this problem, I purchased the program, installed it and now Im not able to open it at all, the same message comes up and it loads.. but nothing happens. Can you help me? :smileyhappy:
    Member
    ecmruss88
    08-30-2011 11:39 PM in reply to: macabyte
    I'm not able to even get that far to open a drawing at all, it won't stop loading and the program never opens?? Would this be to do with the memory on the laptop??
    New Member
    01-25-2013 09:22 AM in reply to: macabyte
    Im in school and taking Drafting. This program is exactly what the message is saying - Education Suite. So no matter the drawings being opened, for as long as you are running this suite it will stamp everything with the Education Sutie border headings.
    Unfortunely I dont think there is a resolution for this unless you upgrade your license. This suite is meant for educational purposes, so any drawings you  create can't be used to make money.
    I have looked into ways to try and remove it, and have come up empty handed.
    ~R.McMullen
    Edited by
    Discussion_Admin
