• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Active Member
    paarch
    My files disappear.
    295 Views, 7 Replies
    12-15-2011 02:20 PM
    First off, this is my current machine:
    27-inch iMac
    3.4GHz Intel Core i7
    8GB 1333 MHz DDR3
    Mac OS X Lion 10.7
    Here is my issue. I WAS running Architectural Desktop 3.3 (I know EXTREMELY OLD) on a PC. Recently purchased new iMac running AutoCad 2012 for Mac and have been transferring files from the old machine to the new one.
    After transferring the files, I open AutoCad for Mac, edit a file, save the file, and close AutoCad. When I go to the location of my recently transferred files, ALL of the files (except the file I editted and saved) have disappeared. This includes, DWGs, PDFs, JPGs, Word Documents, etc.
    The Harddrive available space is the same as it was before I transferred the files. The trash is empty. Other than the One file I editted, it appears that I never transferred the files in the first place.
    I've tried it multiple times... with multiple flashdrives... to multiple folders...  and it keeps doing the same thing.
    HELP!!!!
    Picture 1: Shows available disk space as 987.34 GB before transferring the files.
    Picture 2: Shows available disk space as 986.41 GB after transferring the files.
    Picture 3: After Editting and saving a file... the files that were transferred have disappeared. Available space has reverted to 987.34 GB available. Trash is empty.
    Please use plain text.
    *Expert Elite*
    maxim_k
    Re: My files disappear.
    12-15-2011 07:55 PM in reply to: paarch
    There is a bug in AC 2012 for Mac- if you open andcsave DWG file inside folder, which name contains # sign, AutoCAD erase ALL files inside this folder. So - don't use # sign in folder names. This issue should be resolved in upcoming update for AC for Mac
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Active Member
    paarch
    12-16-2011 01:00 PM in reply to: maxim_k
    THANK YOU! It seems to work. I was tearing my hair out trying to figure this out.
    Employee
    Leaf.chai
    01-11-2012 02:30 AM in reply to: paarch
    Can you have a retest after you get the AutoCAD for Mac 2012 update 1?
    Leaf
    Autodesk Test Engineer
    Active Member
    paarch
    01-11-2012 09:10 AM in reply to: Leaf.chai
    Downloaded the patch.
    Replicated the process I had issues with before, and the files are no longer being deleted.
    However, once I save a drawing and close it, autocad freezes, crashes, and I get the Send Error report pop up.
    So... improved, but still screwy.
    *Expert Elite*
    maxim_k
    01-11-2012 09:24 AM in reply to: paarch
    Does this happens always? with every file?
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Active Member
    paarch
    01-11-2012 09:58 AM in reply to: maxim_k
    Just files that are located within a folder with "#" in the name.
    Doesn't crash in files located in folders without.
    Employee
    Leaf.chai
    01-11-2012 05:57 PM in reply to: paarch
    Have you sent the crash report after quit crash?
    If you send, can you give me your e-mail address which used to send crash report?
    I will try to repro this and keep on tracking with it.
    Leaf
