• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Member
    oleksandr.bolotov
    How to get rid of undesirable styles in a drawing?
    77 Views, 4 Replies
    02-22-2012 05:31 AM
    Is it possibel to select all objects by style (all text objects by style 'Roman' for examble) and then just change style for all them? I
    I also have heard that I can somehow get rid of unused styles (which are already in drawing) by applying "standard enforcement". How can I doo that?
    Are there any other ways to accomplish what I want (replace/remove styles)?
    Member
    danmayer175
    Re: How to get rid of undesirable styles in a drawing?
    02-22-2012 06:09 AM in reply to: oleksandr.bolotov
    QSELECT is the command used to create selection sets using layer, object, style or any other characteristics.  Unfortunately it is missing from AutoCAD for MAC.  Also missing are the very useful tools for drawing standards.
    Distinguished Mentor
    maxim_k
    02-22-2012 12:31 PM in reply to: oleksandr.bolotov
    As a replacement for QUICKSELECT command you can try Lisp routine from my blog -
    Quick Select For Autocad For Mac
    You can select single-line text objects by style with it:
    Command:  SSS
    Select objects for filtering (<Enter> - select all objects):
    Select objects:
     Search for - Text/Attdef/PLine/LIne/Circle/Point/Block/<ALL> - or PICK [Text/Attdef/PLine/LIne/Circle/Point/Block/ALL] <ALL>: t
     Selected: TEXT
     Search under what criteria - [Style/STring/Height/Rotation/Width/Layer/LType/Color/Elevation/ALL] <ALL>: S
     Text style name / <PICK>: Romans
     2 entities found.
    There is no option for MTEXT objects, but you can select them by picking as example:
    Command: SSS
    Select objects:
     Selected: MTEXT
     Search under what criteria - [Layer/LType/Color/Elevation/ALL] <ALL>: ALL
     16 entities found.
    OK, for MTEXT objects try attached LSP (after loading it type SSS_MT, select Mtext object to determine Text Style and all Mtext with the same style will be selected)
    Then you can use Properties inspector to change style of selected objects (Text or Mtext)
    Maxim
    Architect
    MARSS
    http://macacad.wordpress.com
    Member
    oleksandr.bolotov
    03-04-2012 02:08 PM in reply to: maxim_k
    It just selects one object and then it does nothing. Sory it doesn't work for me.
    maxim_k
    03-05-2012 07:11 AM in reply to: oleksandr.bolotov
    Strange... for me it works.
    А вы случайно не из России? Напишите в личку, могу с Вами связаться: чем смогу - помогу.
    Maxim
    Architect
    MARSS
