• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Valued Contributor
    JohnRennie
    Hatch pattern error
    153 Views, 9 Replies
    02-13-2012 07:39 PM
    Is there a way I can identify an error in the acad.pat file?
    I've pasted in a heap of legacy hatch patterns into the acad.pat file, but everytime I open a drawings I get an error message that I have to acknowledge before I can continue.
    Distinguished Mentor
    maxim_k
    Re: Hatch pattern error
    02-13-2012 10:30 PM in reply to: JohnRennie
    Hi John,
    Could you please to review this thread at getsatisfaction.com. It is about hatch patterns in AC LT for Mac, but I'm sure that it also applies to full version of AC for Mac.
    Maxim
    Architect
    MARSS
    http://macacad.wordpress.com
    Employee
    Leaf.chai
    02-15-2012 09:32 PM in reply to: JohnRennie
    Hi User,
    Thanks for connecting Autodesk.
    Can you share you hatch defination to us?
    Leaf
    Autodesk Test Engineer
    Valued Contributor
    JohnRennie
    02-19-2012 08:24 PM in reply to: Leaf.chai
    Hi, I haven't managed to try Maxim's suggestions yet but here are my hatch pattern files. I've since reverted to the original hatch pattern file but I'm still getting the error messages crop up when I go to hatch something, or if I switch drawings.
    My reseller had a look at the .pat file for me and said it was ok, but I did have a revit pattern in there (I think it was the schist pattern)
    The strange thing is it is the same file I used on 2011 and it worked fine. It also waorks fine on the windows version of AutoCAD 2012 too.
    I'm unable to attach a .pat file to the forum post, so is there any other way I can get it sent to you?
    maxim_k
    02-20-2012 09:37 AM in reply to: JohnRennie
    Hi John,
    In order to be able to attach .pat file you have to compress it and attach as .zip archive
    Maxim
    Architect
    MARSS
    Valued Contributor
    JohnRennie
    02-20-2012 01:02 PM in reply to: maxim_k
    Here are the hatch patterns (old and new)
    maxim_k
    02-20-2012 10:21 PM in reply to: JohnRennie
    Hi John,
    Maybe it is strange, but your modified acad.pat works for me well - no warning messages. Maybe the case is in DWG file?
    Maxim
    Architect
    MARSS
    Valued Contributor
    JohnRennie
    02-21-2012 04:00 PM in reply to: maxim_k
    Thanks Maxim,
    I'm not entirely sure what is going on really, as I cant get any errors to repeat in the Windows version.
    I've attached the dwg file for you if you get a chance to look at this too.
    Valued Contributor
    JohnRennie
    02-21-2012 04:08 PM in reply to: JohnRennie
    Actually it must be something else as it comes up with a couple of error messages everytime I go into a hatch command in any drawing.
    Either way it is very annoying, especially as I have reverted back to the original acad.pat file.
    maxim_k
    02-22-2012 02:40 AM in reply to: JohnRennie
    Hi John,
    It appears that you have some ".pat" (with single hatch definition in it) somewhere on AutoCAD Support File Search Path, and this file have an error. An error message should look like this one:
    Check, please, AutoCAD Support File Search Path for additional .PAT files.
    Maxim
    Architect
    MARSS
