• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Member
    Can't compile shapes
    85 Views, 2 Replies
    11-16-2012 09:10 AM
    I have been trying to write my own shape file, but can't get it to compile.  I have used TextEdit to save the file as Unicode-7 and Unicode-8, and I have also used Smultron to save the file as Western (ASCII) and Non-Lossy ASCII.
    Whenever I try to compile my Arrow.shp file, I am told that I have a "Bad shape definition at line 2", and that there is an "Invalid shape element, or bad syntax".
    The text in my shape file is everything between the lines below.
    *1,9,ARROW
    080,8,(-2,1),02C,8,(2,1),0
    I have also tried shapes that use pen up segments and ones that use no special codes at all, only hexadecimal ones.
    Anyone know what I am doing wrong?
    Please use plain text.
    maxim_k
    Re: Can't compile shapes
    11-16-2012 11:07 AM in reply to: benlukes
    A long time ago, when I was using AutoCAD version 12, there was a "golden" rule about shape file definition creation:
    it is absolutely necessary to leave last line in text file blank, i.e. you have to hit Return (Enter) after last text line in shape definition file.
    I successfully used TextEdit.app with default plain text encoding for creation ARROW.SHP
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Member
    11-19-2012 10:42 AM in reply to: maxim_k
    Thank you, that did the trick.
    If that isn't in the documentation (I didn't see it), it should definitely be added.
