• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    New Member
    sellsworth
    CAD for Mac 2012 Pdf issues
    645 Views, 2 Replies
    02-13-2012 09:19 PM
    I'm trying to print some fabrication drawings as an 11x17 pdf file. I have the layout set up to an 11x17 paper size, but when I save/export/publish to pdf, the saved pdf file always ends up as 8.5x11! I've tried using the 'save to pdf' button on the printer dialogue. I've also tried to 'export' to pdf, with override settings to make sure the paper size is correctly set. Still no luck. Needless to say, this is extremely frustrating, and I'm not sure how to fix it. Help!
    Please use plain text.
    Member
    Re: CAD for Mac 2012 Pdf issues
    03-05-2012 10:15 AM in reply to: sellsworth
    Argh!  I am having the exact same problem - except for a 24x36 layout.  I have successfully printed this layout to pdf multiple times before, and now - suddenly something has changed and it will only print to pdf an 8 1/2x11 area of my plot.  WTF?!  How did I break it and how do I fix it!?
    Member
    03-05-2012 11:12 AM in reply to: sellsworth
    I fixed it!
    Here's how I got this to work for me:
    File
    Print
    Paper Size - hit the disclosure triangle
    Select Manage Custom Sizes
    Set the Paper Size dimensions for your layout and set the Non-Printable areas to 0.00
    Ok
    Now you're back to the Print box
    Hit the PDF disclosure trianlge (lower right)
    Save as PDF
    Fill out the info inthe Save dialog box
    Save As, location, etc.
    Save
    done.
