• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Active Member
    rossarch
    AutoCAD LT for Mac, plot style lineweights
    543 Views, 2 Replies
    01-31-2012 07:54 AM
    Hi.  I am just starting out with AutoCAD LT for Mac, moving over from the Windows platform.  I am trying to set up a plot style but notice that the lineweights options are given (.0000, .05, .09, 1.0, etc ).  I can't find a way to input a different lineweight other than the weights given.  Is there a way, or is this a limitation of AutoCAD LT for Mac 2012?
    Distinguished Mentor
    maxim_k
    Re: AutoCAD LT for Mac, plot style lineweights
    01-31-2012 11:53 AM in reply to: rossarch
    You can do this (edit standard lineweights) in Plot Style Table editor :
    Lineweight
    Displays a sample of the lineweight as well as its numeric value. You can specify the numeric value of each lineweight in millimeters.
    If you assign a plot style lineweight, the lineweight overrides the object's lineweight when it is plotted.
    Edit Lineweights
    Modifies the widths values of existing lineweights.
    Displays the Edit Lineweights dialog box.
    There are 28 lineweights available to apply to plot styles in plot style tables. If the lineweight you need does not exist in the list of lineweights stored in the plot style table, you can edit an existing lineweight. You cannot add or delete lineweights from the list in the plot style table.
    Architect
    MARSS
    http://macacad.wordpress.com
    Active Member
    rossarch
    02-20-2012 08:52 AM in reply to: maxim_k
    Thank you for the help!
