• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Active Contributor
    AutoCAD 2013 for Mac - Saving Preferences
    3258 Views, 8 Replies
    08-16-2012 12:56 AM
    Does anyone know if it's possible to set your saving preference to an earlier CAD version?
    I work with a lot of consultants that are still using CAD 2008!  And I hate having to save manually as AutoCAD 2000.dwg.  Also I've notice several glitches if you save as an earlier version and then you accidentally hit save again.
    -G
    Please use plain text.
    maxim_k
    Re: AutoCAD 2013 for Mac - Saving Preferences
    08-16-2012 02:36 AM in reply to: gregory
    Yes, there was a lot of posts here about this, for example:
    http://forums.autodesk.com/t5/AutoCAD-for-Mac/SAVNG-AS-previous-versions-automatically/m-p/3050704#M...
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    Valued Contributor
    David_Stacey
    08-16-2012 02:58 AM in reply to: gregory
    Hi.
    Yes, you can change default save format in AutoCad. It is controlled by an environment variable.
    (setenv "DefaultFormatForSave" "24")
    You could substitute 24 for 36 (2004 format) or 12 (2000 format). Then you're as good as gold.
    Active Contributor
    08-16-2012 09:14 AM in reply to: maxim_k
    Awesome!  Thank You!
    Likng AutoMac 2013 for Mac that much more now!
    -G
    Active Contributor
    08-16-2012 09:14 AM in reply to: David_Stacey
    Set for 2000!  Thanks!
    -G
    Active Member
    08-23-2012 01:16 PM in reply to: gregory
    I didn't quite understand. Would you mind explaining it with more detail, i'd be thankful!
    maxim_k
    08-24-2012 12:17 AM in reply to: AnnieBlanda
    Hi Anna,
    I answered (probably partly) on Get Satisfaction AutoCAD LT forums:
    https://getsatisfaction.com/autocadltformac/topics/suggestion_default_save_as_option-mm9ud
    Here is my answer:
    Hi Anna,
    If you have AutoCAD LT, you have to use solution from my first post here (setting default format for save via Terminal)
    But I want to know which AutoCAD LT you own?
    - If 2012 (then you can use above solution directly)
    - If it is 2013, then which version - from AppStore, or from Autodesk (or reseller), for Autodesk version look for the solution here:
    http://forums.autodesk.com/t5/AutoCAD...
    for AppStore version - I'm not sure exactly about the name of preferences file, so the solution from forums may not work.
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    New Member
    11-26-2012 03:27 PM in reply to: gregory
    I have Autocad LT 2013 for mac and need to change my default save to 2010, does anyone know how I can do this? I have tried a terminal command I found but it didn't seem to work as it probably wasn't for the app store version. Thanks.
    maxim_k
    11-26-2012 11:36 PM in reply to: warwick
    Hi Warwick,
    In order to set default format for save to 2010 DWG in AC LT 2013 from MAS you have to run this command in Terminal:
    defaults write com.autodesk.autocadlt2013 "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 48
    to revert back:
    defaults write com.autodesk.autocadlt2013 "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 60
    For other DWG formats:
    Change "48" in the first Terminal command above to one of the following based on the default format you want to use:
    1 - AutoCAD R12 DXF
    12 - AutoCAD 2000 DWG
    13 - AutoCAD 2000 DXF
    24 - AutoCAD 2004 DWG
    25 - AutoCAD 2004 DXF
    36 - AutoCAD 2007 DWG
    37 - AutoCAD 2007 DXF
    48 - AutoCAD 2010 DWG
    49 - AutoCAD 2010 DXF
    50 - AutoCAD 2010 DWT
    60 - AutoCAD 2013 DWG
    61 - AutoCAD 2013 DXF
    62 - AutoCAD 2013 DWT
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
