• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Product Support
    AutoCAD 2012 Mac: Don't use a # sign as a folder name!
    340 Views, 9 Replies
    10-07-2011 11:18 AM
    Please check out this post for details:
    http://upandready.typepad.com/up_and_ready/2011/10/autocad-2012-mac-dont-use-a-sign-as-a-folder-name...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Distinguished Mentor
    maxim_k
    Re: AutoCAD 2012 Mac: Don't use a # sign as a folder name!
    10-07-2011 12:55 PM in reply to: david.lau
    Hi David,
    Can not reproduce this issue on my Mac. Was trying with the same file names as in video in referenced post. Have tried with AC 2012 and with AC 2011 on Snow Leopard 10.6.8
    Maxim
    Architect
    MARSS
    http://macacad.wordpress.com
    Product Support
    10-07-2011 01:49 PM in reply to: maxim_k
    I was running on a Mac Pro 10.6.8 with AutoCAD 2012.  Can you let me know if there is a difference between:
    #NAME-OF-FOLDER
    #NAME OF FOLDER
    Maybe it is a combination of # and spaces.
    David Lau
    Product Support
    10-08-2011 05:47 AM in reply to: david.lau
    I just tested AutoCAD 2012 mac with the following to folders on the desktop.
    #2011
    #2011 A3
    When I tried to save a file in #2011, it deleted every file on the desktop!  I had to re-create it the folder #2011 A3 to reproduce the test and it deleted all the contents in #2011 and #2011 A3.
    Both these folders had muiltiple .dwg files.  If you and open the file, all files will get deleted regardless of type!  We have a test system so it didn't matter what was deleted.
    David Lau
    maxim_k
    10-08-2011 11:02 AM in reply to: david.lau
    Hi David,
    Have tested again and again with different folder names - can't reproduce though...
    Maxim
    Architect
    MARSS
    Product Support
    10-08-2011 05:55 PM in reply to: maxim_k
    I have included a video in the Up and Ready post.  Can you confirm using the video as reference?
    David Lau
    maxim_k
    10-08-2011 08:53 PM in reply to: david.lau
    Yes, but I can not understand why in my case this does not happen...
    Maxim
    Architect
    MARSS
    Product Support
    10-09-2011 06:14 PM in reply to: maxim_k
    I am using AutoCAD 2012 on Mac OS 10.6.8.
    David Lau
    maxim_k
    10-09-2011 09:11 PM in reply to: david.lau
    OK,
    Get this bug on another machine.
    When I attempt to save new file from AutoCAD 2012 to folder #2011 in Desktop folder (the result - deleting all contents from Desktop). Also when I try to save .dwg file to that location I get message from AutoCAD:
    "Unable to save to drawing /Users/max/Desktop/#2011/Drawing1.dwg. Drawing saved to /Users/max/save6b9c.tmp"
    But: if I create #2011 folder, than copy some file to this folder, open it in AutoCAD - I can save this file to this location but all contents of Desktop folder and contents of #2011 folder with exception of opened file gone away.:smileysad:
    Maxim
    Architect
    MARSS
    Product Support
    10-10-2011 03:33 PM in reply to: david.lau
    I updated the post:
    "To reproduce this problem, you need to also access multiple folders, open and save files in those folders and if and if one of those folders has a # sign it it, the other extra files in that folder will get deleted."
    David Lau
