• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Employee
    dhard
    AutoCAD 2011 for Mac Update 3 (Lion support) is now live!
    3201 Views, 5 Replies
    10-10-2011 12:24 PM
    Hi all,
    I’d like to let you know that Update 3 was officially released just a few minutes ago.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17917944&linkID=15839491
    This update resolves compatibility issues that have been reported while using the software on the latest versions of Mac OS X Snow Leopard (10.6.8) and Mac OS X Lion. It also resolves problems reported by the Customer Error Reporting (CER) utility and other general problems identified after AutoCAD 2011 for Mac Update 2 was made available.
    Thank you,
    Debashis Dhar
    Member
    rsr789i
    Re: AutoCAD 2011 for Mac Update 3 (Lion support) is now live!
    10-15-2011 12:41 PM in reply to: dhard
    I've had massive issues where AutoCAD 2011 crashes consistently. I installed all 3 updates, in the correct order but that didn't help solve the probelm. :-(
    I'm using a Mac Mini 5,2:
    Processor  2.5 GHz Intel Core i5
    Memory  8 GB 1333 MHz DDR3
    Graphics  AMD Radeon HD 6630M 256 MB
    Software  Mac OS X Lion 10.7.2 (11C74)
    Help!
    Member
    rsr789i
    10-16-2011 05:30 PM in reply to: rsr789i
    I want to add that AutoCAD 2011 was working pretty much ok with Lion 10.7.1... is it possible that there was a background change in 10.7.2 that has caused an issue? If so, is there a workaround? Would reinstalling Java help at all?
    Active Member
    omnikurt
    11-16-2011 10:39 AM in reply to: rsr789i
    Completely unusable.  I don't know if 10.7.2 is the issue or not, as I didn't try installing the patch until after I was already upgraded to 10.7.2.  Guess we sit and wait for Update 4, if that ever arrives...
    Active Member
    zeeblake
    11-17-2011 02:37 AM in reply to: omnikurt
    I found a problem with update 3 on a 10.6.8 machine: AutoCAD rised CPU usage to 100% even when idle. However, I closed AutoCAD and started it again, with the same file, and now CPU usage seems right.
    Not sure of what could have caused this, nor how to reproduce it.
    Member
    MDomiteaux
    Re: AutoCAD 2011 closses on opening.
    12-13-2011 01:05 PM in reply to: dhard
    I am running Mac 10.7.2, installed all updates both Mac and Autocad, AC crashes every time I try to open it, This is super frustrating... The autocad credit window opens then a few seconds go by and it closes then nothing for 5 secsonds then the autocad problem window opens saying teh program quit while opening and sends a report to Autodesk.
    any help  is appreciated.
