• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Acrobat X Pro freezes after ACAD Batch Publish
    188 Views, 4 Replies
    11-20-2012 02:07 PM
    If I batch publish from AutoCAD Mac and then try to open it with Acrobat X Pro, Acrobat X freezes.  I can force quit, but then it continues to freeze on ANY PDF file I try to open.  Only a computer restart will free it up.  After the restart, I can open any PDF including the one created with batch publish.  But batch publishing from ACAD causes it to freeze again.  Anyone else experiencing this?
    Please use plain text.
    maxim_k
    Re: Acrobat X Pro freezes after ACAD Batch Publish
    11-21-2012 10:34 PM in reply to: pbfarch
    Do not have such issue.
    Are you trying to open PDF file, after creating, or you have checked an option in Batch Publish dialog "Open when complete"?
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
    11-29-2012 08:52 AM in reply to: pbfarch
    I found it was an issue with my mouse center button click.  Not sure why, but was able to reslove.  Thanks for the response.
    New Member
    03-05-2013 10:00 AM in reply to: pbfarch
    Having this issue as well. Could you explain the mouse wheel fix?
    03-05-2013 10:15 AM in reply to: scasey10
    I thought at the time that it was related to my center mouse click.  But since it has been a problem consistantly.  The only way I have found to fix it is to shut down AutoCAD completely and within a couple of minutes Acrobat X will respond once again. Annoying, but not a show stopper.
