• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD for Mac
    Active Member
    Accepted Solution
    ACAD Mac non-associative dimensions
    191 Views, 3 Replies
    12-26-2011 12:22 PM
    I have been working on a basement floor plan for my house in order to get familiar with AutoCAD for Mac. I ran across the strangest anomaly. When I started to add dimensions, the dimensions I added the first day were all fine, but when I added dimensions the second day, they were all non-associative. For those not familiar with the term, it means the the wall dimension that was 1ft the first day, showed up as 1/8 inch the second day. I have tried everything I can think of without  any solution, specifically… DIMASSOC was correctly set to 2, as it is supposed to be. I tried playing with the other commands such as DIMREASSOCIATE, DIMDISASSOCIATE, and DIMREGEN. None of them helped.
    The drawing segment shows the problem. At this point, I am out of ideas… help!
    Please use plain text.
    Active Member
    Re: ACAD Mac non-associative dimensions
    12-26-2011 12:26 PM in reply to: 729380
    I should have added one other bizarre feature of the dimensioning, on the second day, some dimensions still scaled correctly while others did not.
    Active Member
    12-28-2011 05:02 AM in reply to: 729380
    This is my own followup to my original posting. The problem I discovered is that AcadMac 2012 does not allow associativity with multilines. The solution I discovered is to explode the multilines. There is a list of other things that don't allow associativity but I misplaced where I found the list. If anybody else has that list, I would appreciate seeing it again as I think I may have some other causes for non-associativity.
    *Expert Elite*
    maxim_k
    12-28-2011 08:57 AM in reply to: 729380
    From Help documentation:
    "Associative dimensions support most object types that you would expect to dimension, they do not support the following
    • Hatches
    • Multiline objects
    • 2D solids
    • Objects with nonzero thickness
    • Images
    Associativity is not maintained between a dimension and a block reference if the block is redefined.
    Associativity might not maintained between a dimension and a 3D solid if the shape of the 3D solid is modified.
    Dimensions created with QDIM are not associative but may be associated individually with DIMREASSOCIATE."
    HTH
    Maxim
    Architect
    MARSS
    MacACAD | MARSS
