AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
slow zoom in-out when raster image
5 REPLIES 5
wele_milan
3667 Views, 5 Replies
Hello everybody .. my issue is when i inster image to my drawing .. i cant zoom in-out easy as usual . it become very slow . BTW i'm using Autocad 2013 for MAC Lion . thanks so much .
5 REPLIES 5
maxim_k
in reply to: wele_milan
Try this solution: from Menu select Modify -> Object -> Image -> Quality (IMAGEQUALITY command) and select Draft option. This should increase zooming speed.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
wele_milan
in reply to: maxim_k
Thanks you so much .. thanks not enough for you ..
this is the solution for my problem .
dab.studio
I tried this solution, but in my case it did not work. My problem persists. In my dwg I have more than a raster image; Zoom dynamic or real-time is almost impossible to use. If I try to open the drawing on a windows xp virtual machine, it works much better. The problem manifests itself with AUTOCAD 2012 for Mac with version 2014
maxim_k
in reply to: dab.studio
Welcome to the Autodesk Forums!
What Visual style is current in your drawing?
Try to set it to 2D Wirrframe.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
dab.studio
Yes dwg is in 2D Wireframe... this is my situation
image are all jpg 72dpi
”Boost
