I do have another post in regards to this issue, but would like to get some feedback in general. I used Acad on a PC for many years (started with v13 in DOS), and have consequently learned to enter commands very quickly without any hesitation on the part of the PC. I retired a couple of years ago from practicing architecture full time, but every once in a while I do a small project. Because of my son's enthusiasm for his Mac, I decided to make that change from a PC to a Mac, and I've not regretted that one bit. So now I purchased a copy of Acad LT 2013 for Mac but am getting these brief delays from both kbd entry and icon command selection. For example, if I type in EX for extend, the E comes up right away, but the X takes sometimes several seconds to show. By that time I would have normally entered the numerical distance and completed the command.
I am expecting my Mac (an early 2011 Macbook Pro with i5 and 8GB ram) to be as responsive as my PC was, am I being unreasonable in this?
Does anyone else experience that little delay from kbd or icon command entry to seing it come up in the command line dialog box?
Solved by maxim_k. Go to Solution.
Hi Joe,
I already tried to help you with this issue here: http://forums.autodesk.com/t5/AutoCAD-for-Mac/New-to-Mac-version/td-p/3894508
And as I see the problem is not resolved yet.
Now I have one additional question:
Do you have some third-parity application (such as TextExpander) or some active service (such as "Enable Slow Keys" in Accessibility pane of Mac OS System preferences), that interact with keyboard input on your Mac?
BTW: here is discussion about TextExpander in Apple Support Comunity:
https://discussions.apple.com/thread/3240060?start=0&tstart=0
Maxim
I apologize for the second post on same problem, but I'm trying to approach it a little differently as I'm wondering if I'm expecting too much out of this macbook pro, since the only thing I have to compare it to is my own previously owned pc which had a very fast overclocked i7 and high end graphics card. The thing is that I'm doing straight 2d autocad, and even on lesser pc's have never experienced the delays from input to seeing it on the screen as on this mac (which I do like very much by the way).
To answer your questions, I do not have text expander, and have slow keys turned off.
I used AutoCAD for Mac for some time on 2011 Mac Mini (i5, 8Gb RAM) and have not seen such delays at all.
How long are these delays?
Maxim
Do you have enough free space on your HDD to create additional partition or an external USB HDD (free from data)?
In your place I would try to make a fresh installation of Mac OS into this new partition (or external HDD), install only AutoCAD in this system and test it. This could eliminate current OS problems (if any) and if you will install the new System to an external HDD eliminate HDD problems (if any).
After testing you can safely delete partition and expand your current partition back.
Maxim
I've reloaded Mac osx and still the delays. As I'm using the Mac version I'm finding myself significantly less productive, it does not have as full functionality which I've gotten used to on the Win version, so all things considered, I'm going back to the Win version, which runs very fast even on an old P4 running windows xp. I appreciate your efforts to help me with the Acad LT for Mac issues. Joe
