I'm using autocad for mac 2012 and my move tool has just started playing up.
I select what I want to move and when i type "move", some of the lines just go to random places on the page even though it should move as one entity.
Any ideas what's going on?
Does the same thing happen when you type "m", "_move" or click the Move tool in the ribbon?
Jon
yes, it's happening for every move function and with everything I try moving
saskia
What does the command prompt read during/after the operation?
What happens if you select the Move tool first and then select the objects?
Have you contacted your reseller?
Jon
it says the normal command instructions "specify base point" etc.
It happens when I type "move" first as well.
I don't know who to contact because it's an educational version from autodesk that I'm using for my degree.
It's only happening with move as well, "copy" is fine
Saskia
Check please - maybe the objects you try to move are connected each other with some parametric constraints.
Maxim
May I ask you to clarify what you mean by this? Is there a command to check or edit those? Please excuse my ignorance, I'm not super familiar with the settings of this program, thanks.
Checking in, did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
