Dear AutoCAD for Mac Community,
At the moment I am having trouble on drawing a line correctly in the layout. The line has linetype "ACAD_ISO10W100" and the problem is that on the model this line is been drawing correctly but when I go to the layout the line is not shown as having a linetype "ACAD_ISO10W100". I have attached the file, so you can help me to find a solution or workaround. Thank you very much in advance for your kind of help.
Best,
Ricardo.
Solved by maxim_k. Go to Solution.
Hi Ricardo,
Open Layout with incorrectly scaled linetype.
From "Format" menu select "Linetype..." in Lynetype dialog un-check "Use paper space for scaling" click Save:
Call REGENALL command.
HTH
Maxim
