AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
customised tool set
6 REPLIES 6
993 Views, 6 Replies
customised tool set
Hello
Autocad LT 2013 for Mac
I would like to use my customised toolset (cui file) on anther mac, but can't find a way to copy the file in the first place.
Does anyone know how to do it?
Thanks!
6 REPLIES 6
Hello
Thanks!
hwalker
Your best bet would be to ask in the Autocad for Mac forums
But in Windows in the Start menu there is a program called "Migrate Custom Settings" in which you can import and export your settings. Maybe there is a Mac equivalent.
Howard Walker
Left Handed and Proud
AcadAdamLT
No idea how Autocad LT works in MAC-enviroment but if you know where your .CUI file is located you should be able to copy it and overwrite the current default in the new MAC.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
maxim_k
HI,
Your customization results are in:
~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2013 Standalone/R19/enu/Support/PopMenuRoot.cui - Pulldown menus;
~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2013 Standalone/R19/Support/Workflow.cui - Tool Sets Palette;
~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2013 Standalone/R19/Support/MenuGroup.cui - Commands customizations.
Here the Library folder is in your Home folder, not Library in the root of your HDD. It is hidden by default, to access it:
In Finder on the menu bar, at the top, select Go to reveal the drop-down menu and then hold down the Option key (marked ALT) and you will see the ~/Library folder appear. You may now select this ~/Library folder with your mouse or trackpad.
The path valid for AutoCAD LT pursuased from Autodesk or resellers, for MAS version of AC LT - it is slightly different, I think "AutoCAD LT 2013" instead of "AutoCAD LT 2013 Standalone".
HTH
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Brilliant! It works, thanks for your help!
”Boost
