hope somebody can help. I'm new to Mac and to AutoCAD LT 2014. I have been using the programme for approx 4 weeks with no problems, then when i clicked on the icon in the applications bar this morning the LT icon bounced up and down twice before stopping. The introduction window pops up that says its loading and the small circle of lines next to that go about half way round and then stop and thats as far as the programme goes!
Not sure what is causing the programme to fail to load up!
Would be grateful if somebody has some advice or knows what is wrong?
Many thanks
Mark Watkins
Solved by markw.arch. Go to Solution.
Welcome to the Autodesk Forums!
Hi Mark,
If you already installed SP1 for AC LT 2014 you can try to reset AutoCAD settings as described here:
If no - than download SP1 from here:
install it and try to reset settings as described in my post (see first link)
Maxim
