I am unable to change plot styles and I can't figure out why. I've attached a screen shot of the window that comes up: while I am able to scroll to different styles than acadlt.ctb- the one displayed- there is no prompt to make it change to a new one.
please help
thanx
Solved by maxim_k. Go to Solution.
With this dialog you can only create or edit plot style table files, but not change plot style in model/layout.
You can set plot style via Properties palette:
or via Page Setup dialog:
Maxim
I can get the linework in paper space to print according to the monochrome.ctb, but the linework in model space (viewport) still prints according to layers. I've checked my ctb file for errors, but found nothing. The "plot style table" option is monochrome, but the "plot style" option only offers "ByColor". What am I doing wrong?
Hi there,
Cannot seem to get my plot styles scroll down to work when printing. See attached image. Continually has exclamation mark and the 'Reveal in finder' used to work and now does not. Help needed and appreciated...
j
@Anonymous wrote:
I cannot get the 'Reveal in finder' to work under the 'plot style table dialog box'. It just shows a question mark.
@I cannot understand: two lines above you wrote:
@Anonymous wrote:
Now the ctb is located correctly and the page set up finds it.
Why you desided that ctb file is licated correctly if it still has question mark?
Where you see question mark?
Could you please elaborate? Maybe attach screenshot...
In addition - the "colorized" plot output can be cased by two other reasons:
- you are using Visual style different from 2D Wireframe inside viewports in the Layout
- you have objects in your drawing with True colors assigned - plot style table works only for colors from 1 to 255 (AutoCAD Color Model)
Maxim
