So when I select an object and move it, copy it, change it in any way; every time I move it around the screen the object starts 'drawing' itself slowly. For example if I move a circle from one location to another, when I rest the cursor it will start rendering the circle slowly from one point until it is complete, if I move the cursor at all, it starts again from blank. This gets very annoying when I am selecting multiple objects and cannot see what I actually have selected until I place them again.
I don't believe it's an issue with the computer as I'm running this on a new top-spec Retina. Is there some setting that I can change so that when I select objects, it shows the preview as is, not slowly drawing each line?
Solved by bshfrd. Go to Solution.
Thanks for posting your found solution, helped me sort out the slow redraw I was having, no idead what set my DRAGDP1 to 0...
