AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
autocad lt for mac 2013
8 REPLIES 8
Message 1 of 9
Gioskaly
767 Views, 8 Replies
anyone who knows how to;
-change the save as default from 2013 to 2004 or similar
-there is no print preview in print menu(no chance to see what I am printing)
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: Gioskaly
About default 2004 DWG format for save:
If you are using AC LT from Autodesk or resellers, you can try small application from my blog:
http://wp.me/p10TA2-cX
If you are using AC LT from Mac App Store you have to run this command in Terminal:
defaults write com.autodesk.autocadlt2013 "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 24
to revert back:
defaults write com.autodesk.autocadlt2013 "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 60
For other DWG formats:
Change "24" in the first Terminal command above to one of the following based on the default format you want to use:
1 - AutoCAD R12 DXF
12 - AutoCAD 2000 DWG
13 - AutoCAD 2000 DXF
24 - AutoCAD 2004 DWG
25 - AutoCAD 2004 DXF
36 - AutoCAD 2007 DWG
37 - AutoCAD 2007 DXF
48 - AutoCAD 2010 DWG
49 - AutoCAD 2010 DXF
50 - AutoCAD 2010 DWT
60 - AutoCAD 2013 DWG
61 - AutoCAD 2013 DXF
62 - AutoCAD 2013 DWT
About preview - you can use "Open PDF in Preview" in Print dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Gioskaly
in reply to: maxim_k
Many thanx Maxim, one more question;
I downloaded some title box templates with .dwt extension, where should I put this file in my Mac. Or any other solution to see these templates when working in layout window?
GIO
Message 4 of 9
maxim_k
GIO
Hi GIO,
You can put templates file to the "~/Library/Application Support/Autodesk/local/AutoCAD LT 2013 Standalone/R19.0/enu/Template" folder (if you have not changed default Drawing template file location in AutoCAD Preferences). Then when you will create new drawing you don't have to search for these templates, them would be at hand in the Drawing template selection dialog.
You can create your drawings with these templates and Title blocks will be ready for use in new file.
You can also just insert Title blocks from templates to your existing drawings, for example by copy - paste via clipboard.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
Gioskaly
Hi Maxim,
Many thanx for your help, it worked a lot.
GIO
Message 6 of 9
Hi my name is Samuel, im from Montréal Qc. I wanted to try Autodesk and have some fun creating things so i dowloaded it on my desktop but the application dont want to install, do you have any clue, maybe i got too do something before the installation. Will be nice if you could help me !
Thx, Sam
Message 7 of 9
maxim_k
Hi Sam,
What do you mean "application don't want to install"? What do you see?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
Hi Maxim, sorry for my english it is not my first language. So what i mean his that i think that the free software version that i've download is not compatible with my Mac Osx or something because when i try to open the file, it say that Autocad 2013 French is unrecognized. Maybe i didint download the right version for my Mac i dont know. im searching for the answer ! Thx btw to respond that fast see yah
Message 9 of 9
maxim_k
Hi Sam,
If you see an alert from Mac OS, that DMG is not recognized and couldn't be open, this could mean that DMG was corrupted during downloading. Try to redownload installation image again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
