i'm trying to turn off the visibility of the viewport frame so that it does not plot
from the layout tab view with paper space engaged, i've tried:
- turning the layer off
- freezing the layer
- viewport freezing the layer
- changing the layer to no-plot
- all of the above in various combinations
what am i missing?
i'm pretty sure someone can help me realize what a simpleton i am 🙂
thanks up front!
Solved by adamchr. Go to Solution.
figured it out
i created a polyline that somehow retains its layer characteristic at the moment i used it as an object to create the viewport
even though i changed its layer via the property manger and it appeared to take the change, it didn't really
i was frustrated because the viewport pretended to be on the right layer when checking it in the properties manager, but somehow retained its original layer designation
so, to fix
set the polyline to the viewport layer first
mview
object
click on the shape
now it should operate as expected
YMMV 🙂
