AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Windows OLE Objects
6 REPLIES 6
izernet.ada
8332 Views, 6 Replies
Windows OLE Objects
Where are the images that I pasted on my drawing?
Just I can see boxes with a dialogue, this dialogue says "windosw ole objects".
Anyone knows what happened with mi images?
Regards
6 REPLIES 6
maxim_k
in reply to: izernet.ada
Welcome to Autodesk Forums!
OLE technology doesn't supported on System level in Mac OS.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
izernet.ada
in reply to: maxim_k
What can I do to view these objects?
The only one thing that I can do is re insert as a raster reference image with image file.
Thank you.
Sent from my iPhone
maxim_k
Yes, you quite right, in Mac OS you can only insert raster images as external references.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Then,would The Autodesk able to  make The OLE Objects  READABLE  in the MAC OSX system later?
I'm in a great need of some sheets in my drawing works.
To my regard.
Thank you.
pendean
Read the topic again.
>>>WINDOWS<<< ole objects.
Windows, OS, by Microsoft.
OLE, by Microsoft through Windows OS.
AutoCAD for Windows uses Windows OS features like OLE.
MAC OS by Apple.
MAC OS has no OLE ability.
AutoCAD for MAC has no OLE, since it is not found in the MAC OS.
Applications linking is done at the OS level: otherwise every application will need custom code for each specific other program and the nightmare of coding will grow exponentially and then really be unstable.
This post is not meant as an insult, just pointing out facts that some of us here are glossing over. OLE is not in the MAC OS, only Apple can make it happen.
in reply to: pendean
Hi,pendean.
Thanks for your response and guidence.
Well,i see,i konw how to get over it:Let's forget about the way to find the Windows OLE Objects in MAC.Smiley HappyMission impossible.
So,Tim Cook have one more work now.
Thank you again!
wiki
”Boost
