AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Very Slow Drawing on LT 2013
3 REPLIES 3
blpendley
271 Views, 3 Replies
I recently upgraded to Mac OS 10.9.2 on a MacBook Pro with Retina display. Before upgrading the OS I installed both Service Pack 1 and Service Pack 2 for ACAD LT for Mac 2013. It is currently running at version G.55.M.208. The problem I am having now is that everything draws very slowly. For instance, I can select the Center Radius Circle tool and begin drawing a simple circle. A circle with a radius of 10" takes approximately 12 seconds to draw on the screen. What can be done to fix this issue. I obviously cannot work with this situation.
Brandon
3 REPLIES 3
maxim_k
in reply to: blpendley
Hi Brandon,
How complex is the drawing file where you have troubles?
Does this happens even in new empty file?
What do you mean?
You pick center, than you pick (or type radius) and then you wait 12 sec to circle appeared on screen?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
blpendley
in reply to: maxim_k
Hi Maxim,
Yes, this happens even in a new drawing file. I would select the center point, pull the cursor out 10"and click, then it would take about 12 seconds to draw the circle; pixel by pixel. I have been reading other forum post this morning and saw someone reference the "DRAGP1" variable. Mine was set to 0 but I changed it to 1000 since the post I read said it should be set to below 5000. It seems to be working completely fine now. I'm not sure if that variable was the solution or not.
What are your thoughs in case this happens again?
Brandon
maxim_k
Yes, the case is in DRAGP1 system variable (sometimes it resets to 0 after AutoCAD crash), the default value is 5000, and you can set it to 5000.
That was the real solution.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
