I am quite confused: I have drawings units set to inches, but i am unable to type any symbols in relation to a dimension. I can only enter in straight numbers. for instance:
i CAN type: 36
i CANNOT type: 3' or 36"
Obviously having to write every unit in straight inches is extremely tedious. i should be able to type 1.5' and come out with a line that is 18" long.
Any ideas?
Solved by maxim_k. Go to Solution.
go metric.........
from the HELP
Specifies the current unit of measurement and the precision for the current units.
Sets the current format for units of measure. The values include Architectural, Decimal, Engineering, Fractional, and Scientific. The Engineering and Architectural formats produce feet-and-inches displays and assume that each drawing unit represents one inch. The other formats can represent any real-world unit.
Hi aploporto,
I'm from "metric" world, and don't use Imperial units in my daily work.
But if you set units in you DWG file to "Architectural" or "Engineering" you can input distances in any of these formats:
1.5' (one and a half feet) or 18" (eighteen inches); 36" (thirty-six inches) or 6' (six feet) and so on.
As for Dimension style, if you want to see only inches in dimension text, setup Dimension style with Unit format "Fractional" and Suffix " (go to Dimension Style -> Modify -> Primary Units tab). If you want to see 1'-6", set unit format to "Architectural" or "Engineering".
So, when you draw the line from some point and type 1.5' in dynamic input - you get line one and a half feet long, or eighteen inches long.
Maxim
You should be able to use those suffixes for feet |'| and inches|"|. It is working on my AutoCAD mac. If you can post the file we might be able to help you.
KC
I am having a similar problem, I am not sure about what units I am actually drawing in. When I try to draw with specific units i have no idea it is drawing 16' or 16". However, when I open up drawing that i have done a PC it recognizes the units. How do I put set up the units?
