Am using Autocad LT 2013 on Windows platform using FusionWare on a Mac Pro. This is a company owned computer and all files are saved to a server. This problem began occuring after we returned to work on Jan 2. I will be working in drawing and save regularly. Additionally autosave is set for 5 minute intervals.
Several times a day I get a message saying
"Unable to save drawing\\server\filename.dwg. Drawing saved to \\server\filename\savF676.tmp."
When I check the folder where the drawing is supposed to be there is a "filename.dwl" and the "sav676.tmp." files but the original .dwg doesn't show up in the list.
If I save as the file to my desktop it is fine, but I then have to move it back to the server per company policy. This is extremely tedious to say the least. This happens several times a day so far.
The IT guy has twice reset the permissions for the Directory so the files are not Read Only (although when I check the main client folder and sub folders from my computer the Read Only option is checked and I cannot change this).
Another Autocad user in the office, LT 2013, says this has happened to him but only occasisonally.
Also, several times I have noticed an alert pop-up that says something about "Unable to map network drive G:\\" but clicking on the notice just expands the message with no suggeston for solution. G Drive isthe primary server in our office. The only PC computers in our office are used for Autocad, the rest are all Apple products and the IT tech is a Mac guy.
Boy, between this and the AutoCAD LT Forum you are getting no satisfaction with FusionWare.
I think it is time to tell Management that they have given you a sinking raft when you seem to be the only user in the world with this combination.
The 4th post in this thread is interesting:
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
