I am working on a Mac with AutoCad LT2013.
Trying to turn the view in Viewport with setting the UCS 3-point command and then Plan View - Current UCS.
For some reason the view does not turn when I work on my laptop, but it is working on my iMac (same drawing file). I suspect there is a hidden setting that I have changed without knowing what I was doing.
Does anyone know how to solve the problem?
Many thanks!
Could you check with Customize dialog "Plan, Current UCS" command - run CUI command and search for "Plan, Current UCS" command in it.
It should look like this:
Maxim
Hi Maxim
the macro was RCDATA_16_UCSVIE, changed it to the one you gave me and now it works!
Thanks a lot for your help!
UL!
