AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Tried to install AutoCAD Mac and got an "installation failed" message.
12 REPLIES 12
Message 1 of 13
1503 Views, 12 Replies
Hi, I attempted to install AutoCAD Mac and got the following message:
I use OSX 10.8.4.
12 REPLIES 12
Message 2 of 13
philip.s
Hi Scott!
Can you please try the solution listed in the following forum thread, specifically repair of the access rights on the respective volume with Disk Utility followed by an uninstall and reinstallation.
Message 3 of 13
in reply to: philip.s
I followed the instructions in the thread you referred me to. I was still unable to install AC '13. Do I need to install AC '12 first? I'm downladed a trial version.
Scott
Message 4 of 13
maxim_k
Welcome to the Autodesk Forums!
Which installer (DMG file) you are using? Could you provide the name of DMG file you are using?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
maxim_k
Of course, you don't need to install 2012 version first in order to be able to install 2013.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 13
in reply to: maxim_k
AutoCAD_2013_English_Mac_OSX_R1.dmg
Message 7 of 13
maxim_k
Hi Scott,
Yes it is correct installer.
If the solution with repairing permissions did not help you, could you try to create new account on your Mac with administrative privileges and start installation from this new account?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 13
I also have the same problem.  I'm using the correct installer, I have tried repairing disk permissions and also tried installing on a new account with admin rights....no joy!
Has anyone found a fix for this yet?  It's very annoying!
Mike
Message 9 of 13
maxim_k
What OS do you have on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
I'm running Mountain Lion 10.8.5. on a
Mac Book Pro
13 " Retina
256 Flash
8G Ram
2.6 i5
I have tried the most up to date installer without any luck.
Any advice appreciated!
Mike Burwood
m. 07973 689 047
e. mike@pahire.com
Message 11 of 13
maxim_k
Hi Mike,
Could you post here Console messages, that you can see in Console.app during installation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
I have just tried once again to reinstall it.
Here is the last few minutes of console:
08/10/2013 12:25:05.572 warmd[41]: [_bootcachectl_playlist_dir_for_user:2529] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C failed: 13 Permission denied
08/10/2013 12:25:05.572 warmd[41]: [_bootcachectl_playlist_exists:467] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C/app.com.apple.Console.playlist failed: 13 Permission denied
08/10/2013 13:25:22.369 com.apple.launchd.peruser.501[136]: ([0x0-0xba0ba].com.apple.ActivityMonitor[4008]) Exited: Killed: 9
08/10/2013 12:25:22.371 warmd[41]: [_bootcachectl_playlist_dir_for_user:2529] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C failed: 13 Permission denied
08/10/2013 13:25:24.828 com.apple.launchd.peruser.501[136]: ([0x0-0xb90b9].com.apple.Terminal[4001]) Exited: Killed: 9
08/10/2013 12:25:24.830 warmd[41]: [_bootcachectl_playlist_dir_for_user:2529] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C failed: 13 Permission denied
08/10/2013 13:25:32.936 DiskImages UI Agent[4026]: *** WARNING: Method userSpaceScaleFactor in class NSWindow is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
08/10/2013 13:25:34.236 DiskImages UI Agent[4026]: *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
08/10/2013 13:25:45.992 CoreServicesUIAgent[4023]: Error: qtn_file_apply_to_path error: Read-only file system
08/10/2013 13:25:49.836 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 13:25:50.105 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 12:25:51.139 warmd[41]: [_bootcachectl_playlist_dir_for_user:2529] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C failed: 13 Permission denied
08/10/2013 12:25:51.140 warmd[41]: [_bootcachectl_playlist_exists:467] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C/app.com.apple.installer.playlist failed: 13 Permission denied
08/10/2013 13:25:51.978 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 13:26:03.522 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 13:26:08.014 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 13:26:13.768 coreservicesd[30]: Application App:"Installer" [ 0x0/0xc40c4]  @ 0x0x7fbc53a3c600 tried to be brought forward, but isn't in fPermittedFrontASNs ( ( ASN:0x0-0xc50c5:) ), so denying.
08/10/2013 13:26:13.768 WindowServer[1826]: [cps/setfront] Failed setting the front application to Installer, psn 0x0-0xc40c4, securitySessionID=0x186b0, err=-13066
08/10/2013 13:26:27.948 sudo[4095]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/bin/chmod
08/10/2013 13:26:27.950 sudo[4095]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/bin/chmod
08/10/2013 13:26:27.956 sudo[4102]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/bin/chmod
08/10/2013 13:26:27.959 sudo[4102]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/bin/chmod
08/10/2013 13:26:27.971 sudo[4109]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/usr/bin/defaults
08/10/2013 13:26:27.976 sudo[4109]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/usr/bin/defaults
08/10/2013 13:26:27.990 sudo[4120]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/usr/bin/defaults
08/10/2013 13:26:27.996 sudo[4120]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/usr/bin/defaults
08/10/2013 13:26:28.019 sudo[4134]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister
08/10/2013 13:26:28.021 sudo[4134]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister
08/10/2013 13:26:28.093 sudo[4150]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister
08/10/2013 13:26:28.096 sudo[4150]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister
08/10/2013 13:26:28.110 sudo[4158]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chown
08/10/2013 13:26:28.117 sudo[4158]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chown
08/10/2013 13:26:28.129 sudo[4169]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chmod
08/10/2013 13:26:28.131 sudo[4169]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chmod
08/10/2013 13:26:28.190 sudo[4183]:     root : can't open /private/etc/sudoers : Permission denied ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chmod
08/10/2013 13:26:28.194 sudo[4183]:     root : no valid sudoers sources found, quitting ; TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.Pgp5UY/Scripts/com.autodesk.autocad2013.h4lmFr ; COMMAND=chmod
08/10/2013 13:26:29.206 Installer[4040]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
08/10/2013 13:26:29.364 Installer[4040]: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
08/10/2013 12:26:36.919 warmd[41]: [_bootcachectl_playlist_dir_for_user:2529] Assertion failed: ((*__error()) == 2): stat'ing /var/db/BootCaches/9849DEF0-D3FF-4042-98E6-45983430428C failed: 13 Permission denied
08/10/2013 13:26:38.050 com.apple.launchd[1]: (com.apple.qtkittrustedmoviesservice[4018]) Could not terminate job: 3: No such process
08/10/2013 13:26:38.050 com.apple.launchd[1]: (com.apple.qtkittrustedmoviesservice[4018]) Using fallback option to terminate job...
Any ideas?
Regards.
Mike
Message 13 of 13
maxim_k
Hi Mike,
Are you using root account?
I think, that you have the same issue as here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-2013-Installation-Failure-Mac-OS-X-10-8-5/td-p...
Something wrong with your sudores file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
