AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Toolbars and Menus Missing in AutoCAD LT 2013 for Mac
25 REPLIES 25
Message 1 of 26
31275 Views, 25 Replies
I intalled AutoCAD LT 2013 for Mac and the Menu Bar (not a ribbon) and the Tool Bars are missing.  When it initiated all of the UI tools were missing, ei command line, status bar, layer, properties, references, etc.  I manually added those components through commands.  But, the Menu bar and Tool Bars are NO Where to be found.  Even when I type in "TOOL" nothing happens.  In addition, after using this for a week, I have crashed it 12 times usually in the middle of a command.  Hot grip use crashes it for example.
Has anyone else encountered these problems?  Found a solution?
Thank you!
Angela
Tags (1)
25 REPLIES 25
Message 2 of 26
wei503
Hi Angela,
Regarding to the menu/tool palette missing, could you please try the steps below:
click AutoCAD LT 2013 menu > Preferences > go to tab Applications > click Reset Application Options button
About the crashes, did you send out the crash report? If so, please let me know what email you input when sent the report.
And please let me know the version of your AutoCAD. You can get it by click menu AutoCAD LT 2013 > About AutoCAD LT 2013
Wei
Wei Ma
AutoCAD for Mac QA Manager
Message 3 of 26
in reply to: wei503
I performed the reset.  No change.  The error reports were sent under DJAngelaV@yahoo.com .  Thank you.
Message 4 of 26
in reply to: wei503
I am also having the same problem. I have tried resetting the application options. It seems to make no difference. I have no menu and no tools in the tool palette.
Message 5 of 26
I have also a simular problem.
My autocad was crashing and now there are no tools on the left an my title bar is gone
Message 6 of 26
maxim_k
Have you tried to Reset Application Options as described in post #2? here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/Toolbars-and-Menus-Missing-in-AutoCAD-LT-2013-for-Mac/...
maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 26
in reply to: maxim_k
Hi
Maybe I did something wrong yesterdag when i tried it, but now it works with the preferences!
I reinstalled autocad and it's back.
Thanks a lot
Lieselore VDC
Message 8 of 26
resetting the options didn't work for me. It's still unusable.
Message 9 of 26
Did you reinstall your autocad?
Message 10 of 26
wei503
If reset does not work, maybe there are some permission problems.
Please try this solution:
http://upandready.typepad.com/up_and_ready/2013/02/autocad-lt-2013-for-the-mac-missing-menu-and-tool...
Wei
Wei Ma
Message 11 of 26
in reply to: wei503
I did this and it works...but now my macros/micros that I created myself are gone and I need them back immediatey. Please help!
Message 12 of 26
maxim_k
Welcome to Autodesk Forums!
Please tell what EXACTLY did you do?
If you trashed
~home\Library\Application Support\Autodesk\roaming\AutoCAD LT 2013 Standalone folder, than it is possible to find your macros in the Trash. So don't empty your Trash, instead go to it and copy all files with .CUI extension to the safe place.
Then report here.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 26
Hi there,
This has just happened to me on the 2015 version. The attached screen grab is the only menu I have. Do I need to 'reset Autocad', 'Reset palettes' or remove from my computer and reinstall? I'm worried about losing my settings.
Ruth
Message 14 of 26
maxim_k
Hi Ruth,
Which settings do you mean?
Can you describe in more details how this happened?
Resetting palettes should not affect any settings you've made, but this possibly will not help.
Resetting AutoCAD will remove all menu and command customizations.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 26
I've just reinstalled Autocad and it's worked – sorry, probably should have tried that first. Thanks very much for the swift response.
Message 16 of 26
Message 17 of 26
maxim_k
Good to hear.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 26
Hi Maxim,
One more query – since reinstalling I'm now getting this error when I go to print (attached). Any ideas how I resolve it?
Many thanks
Ruth
Message 19 of 26
maxim_k
Hi Ruth,
Sorry, but there is no attachment. I cannot see the alert you mentioned.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 26
Sorry, try again.
”Boost
